Mounting Pots
rmb550
Mounting Pots
Post by rmb550 »
My ALPHA pots have the anti-rotation tab on them. Is it customary to punch the chassis for that, or do most builders just cut it off?
rmb
heisthl
Re: Mounting Pots
Post by heisthl »
Unless you're copying a BOGEN cut it off and use a 3/8" intertooth lock washer.
www.RedPlateAmps.com
Re: Mounting Pots
Yeah they just snap off.
rmb550
Re: Mounting Pots
Post by rmb550 »
Thanks guys, I just got the box of Mouser parts. Need to design the chassis next.
Re: Mounting Pots
The only reason to keep the tab is if the chasis you are using has the small locating hole by the shaft hole.
