Hi Guys
Maybe I'm hearing things I'm not sure, but I have the feeling the sound of my Ceriatone OTS has changed a bit. It's almost as if there's a thin blanket over the sound. I have the feeling at first this happened after the amp was on for 10 minutes or so. You could hear a sudden (smal) change. Now I think it's constant.
I have a Kleinulator in the loop. I have both a regular and (since last night) a 19 inch version. Plus a G-Sharp and a Dynacord CLS222 Leslie (made true bypass).
I'm going to buy a cable tester this afternoon to rule out bad cables.
Do any of you have any ideas??
Thanks a lot for your help.
Greets from Holland
Steven
thin blanket over Ceriatone OTS
Re: thin blanket over Ceriatone OTS
95% of the time this is a bad tube. The cable tester won't do what you want as a bad sounding cable can test good but still sound bad. I'd start by swapping some tubes, especally V1.
Thanks A LOT for your help. I'll try to find something that goes well with the JJ's
Steven,
Groeten van een overseas Dutchboy in New York!
Like Bob said, usually the tubes go bad but many many times the issue is a cable or another factor outside the amp. Check this first before diving into the amp.
Veel geluk!
jelle
Veel geluk!
jelle
Yealous
I love New York
Tnx Jelle
I love New York
Tnx Jelle
