I have no idea what's wrong here...
Edit: Oh, never mind.  I feel like a moron.  One of the caps is backwards.  That will do it every time.
						Voltage doubler, let some smoke out!
						Re: Voltage doubler, let some smoke out!
Did you let the magic smoke out?
- skyboltone
It's wired wrong. The positive side of the lower cap goes to the ground; i.e. one end of the HT winding, and the can goes to the neg terminal; i.e. the lower pair of diodes. The can side of the upper cap goes to ground.
you're too quick for me Phil. Good job!
No, only the diodes. They're cheap. I'm working through a bag I got from Mouser a while ago. I think, including solder and the power to melt it, maybe I wasted $0.50. Tranny is still good.Structo wrote:Did you let the magic smoke out?
I run this thing off a surge protector. It tripps off every now n then.
Thanks. I posted the picture because I was sure there was something I just didn't see. I figured it out while I was out walking the dog. Sometimes, it is best to walk away from a problem that has no obvious solution.skyboltone wrote:It's wired wrong. The positive side of the lower cap goes to the ground; i.e. one end of the HT winding, and the can goes to the neg terminal; i.e. the lower pair of diodes. The can side of the upper cap goes to ground.
