OD footswitch only
andrew
OD footswitch only
Post by andrew »
Hello, my amp has just one switch which is for the OD. How would I wire it up for a 5-pin midi cord? I saw the post for an OD and PAB double footswitch but I only need the OD. Thanks all!
tubedogsmith
Re: OD footswitch only
Post by tubedogsmith »
Just don't use two of the five wires. Of the other wires use one for the switch, one for your LED and one to ground.
Stanz
Post by Stanz »
If you are only using OD you can either go 1/4" and use the switch to ground the relay circuit, or use and xlr mic cable (or 1/4" TRS). Otherwise, if you already are set to go with 5 pin din or midi, like tubedogsmith said, just use the wires you need. Although, if you are using a 5 pin connector why not add in the PAB? But to each his own.
andrew
Post by andrew »
I had put the footswitch project on hold but now I'll go with the 1/4". Thanks!
