VVR, not sure I like the effect
billyz
Post by billyz »
I just implemented the VVR in a fixed bias amp. two 6v6's, wreck style front end. I believe it is installed and working properly, voltages track as expected.
I am reducing the voltage to the entire circuit.
It does take a second for the voltage to stabilize after adjusting. I guess my main issue is, and I should have expected this, the distortion increases and it's gets dark and a bit muddy sounding. Except for minor reductions, which are barely noticeable. I was hoping for a more transparent effect. What are others finding.
BTW, the quality and design are second to none.
UR12
Re: VVR, not sure I like the effect
Post by UR12 »
billyz wrote:I just implemented the VVR in a fixed bias amp. two 6v6's, wreck style front end. I believe it is installed and working properly, voltages track as expected.
The voltages do take a second to stabalize. This is because the caps are discharging slower that you are turning the knob and this is normal. I don't think your distortion should be increasing when regulating the whole amp. This is not my experience. as far as sounding dark or muddy sounding. Have you tried it with another speaker cab?
billyz
Post by billyz »
Hi Dana,
I have only tried a 2x12 cab so far. If the distortion should not increase then I do have a problem. The amp sounds good , only when I turn the voltage down does it start to " Brown Out" . I only just got it working so I may have a few bugs.
billyz
Post by billyz »
Well my bad. I did some tube swapping and rechecked the bias. Also, I did not have a knob on the pot so I think I was really turning it down more than I thought. Below 11 o'clock is when it starts misbehavin. It does get darker, but I think the 6v6's have alot to do with that too.
It seems to be working as described.
I just got this one up and it's not all done. Seems they all are individuals and need tweaking to get them where I want them.
UR12
Post by UR12 »
billyz wrote:Well my bad. I did some tube swapping and rechecked the bias. Also, I did not have a knob on the pot so I think I was really turning it down more than I thought. Below 11 o'clock is when it starts misbehavin. It does get darker, but I think the 6v6's have alot to do with that too.
No problem Billy. It definately shouldn't have been working as you described. My next suggestion was going to be to check your bias. I have had a few people not have the voltage on full when they set thier bias and then when they cranked the voltage to max the were overbiased and caused the amp to be a little lacking. Glad you got it sorted out and just let me know if you need help with anything. And you are right about them all being different ("individuals") Kind of like kids :lol:
Pongo316
Post by Pongo316 »
Got a gut shot ?
billyz
Post by billyz »
I replaced the two resistors with 330k and I like it better. I think I might even go to 470k.
Here is a pic before I changed the resistors.
Pongo316
Post by Pongo316 »
billyz wrote:I replaced the two resistors with 330k and I like it better. I think I might even go to 470k.
Carbon comp resistors ? hows the noise level ?
billyz
Post by billyz »
Noise is not a problem. I used them bad old caps too. Sounds real nice.
nickt
Post by nickt »
Which two resistors are you talking about? The VVR bias circuit? Or something else?
billyz
Post by billyz »
on the VVR board resistors R1 and R5 I believe. Dana gives a very detailed installation tutorial with the Board. Also, describes how to change these resistors to adjust the bottom range of voltage drop.
nickt
Post by nickt »
billyz wrote:on the VVR board resistors R1 and R5 I believe. Dana gives a very detailed installation tutorial with the Board. Also, describes how to change these resistors to adjust the bottom range of voltage drop.
Instructions? ... Hey!! :shock: ripped off!! :D
Dana: any chance of PM'ing the install instructions? Mine came with only it's bubble wrap for company.
billyz
Post by billyz »
I downloaded them . Or Dana emailed them, I don't remember. I am sure Dana would send you some if you bought the board from him.
UR12
Post by UR12 »
pm sent
nickt
Post by nickt »
billyz wrote:I downloaded them . Or Dana emailed them, I don't remember. I am sure Dana would send you some if you bought the board from him.
Yes Dana's a good guy. "ripped off" is with tongue firmly planted in cheek. :wink:
