Never found the need... But, it could certainly be done.Elcabong wrote:Paul,
the rating of this model is rather on the low side. Have you ever tried to double the contacts i.e. wire 2 sections in parallel?
Recommend a cheap(er) impedence selector switch?
Re: Recommend a cheap(er) impedence selector switch?
I have tried yesterday as I was wiring one and I was unable to fit 2 wires in the terminals. They are too small.paulruby wrote:Never found the need... But, it could certainly be done.Elcabong wrote:Paul,
And I am still concerned about the rating of this switch! It may work for now but it certainly does not look very sturdy. I will try to find a replacement that will fit with my faceplate...
