Another 15w Liverpool Combo
UR12
Post by UR12 »
Just finished up this 15 watt Liverpool build and thought I would share some pics. This one is also a combo with 2 8ohm Sammi 300B50s for a 4 ohm load. It has the custom 10.5K OT and fixed bias. It also has the fixed bias VVR2 board installed. B+ is around 330V and goes down to about 31v. Can caps were used instead of the 6 mallorys. I took the original board layout from the Liverpool and added a couple of .1mfd caps and 1M resistors to the board to isolate the dc on the pots when running the VVR at very low voltages. I also moved the EL84 1.5k grid resistors to the board instead of the tube sockets. I have them added like the Marshall style 18w. All of the original components on the board are in their original location. The layout is perfect for adding a VVR to any Liverpool or Express where you are varying voltages in the whole amp.
The cab came from Reason. I got it uncovered and I finished all of the tolex, grill cloth and piping myself. Anthony makes some killer cabs!
Ron Worley
Re: Another 15w Liverpool Combo
Post by Ron Worley »
Beautiful stuff Dana, as always.....
Do you have any info on Reason cabinets- I've never heard of them...
Thanks!
Ron
UR12
Post by UR12 »
Ron Worley wrote:Beautiful stuff Dana, as always.....
Thanks!
Ron
Anthony at Reason just combined efforts with Obeid Khan, who used to design amps for SLM (Think Crate/Ampeg amps) Anthony and Obeid have come up with a new Killer amp line and they can be reached at Reasonamps.com. Before they had the new amp line Anthony was doing cabinets for a bunch of different boutique builders. You got me wondering now if he is still making cabs. You can contact him at info@reasonamps.com. I got to meet both of them at the NY amp show and the new amps are simply amazing.
pureoldsound
Post by pureoldsound »
Dana we need clips :lol: I want to hear those sammis with that amp. I might load a cab with some sammis as well....
andrew
Post by andrew »
What presence control did you use?
UR12
Post by UR12 »
andrew wrote:What presence control did you use?
I went with the traditional 5k with DC on it for this build. I usually go the other way on the liverpools but wanted to try it this way on this one.
I hope to get some clips of the amp before it finds its way to a new home.
Cool amp Dana. 8)
Reason built my D'Lite head cab.
The one in my avatar. :D
UR12
Post by UR12 »
Structo wrote:Cool amp Dana. 8)
Thanks! I usually build my own cabs but those combos are a PITA. I built this amp in between other builds and I really didin't have time to build the amp and cab too. Anthony hooked me up and I would highly recomend him to anyone needing a cab. The new Reason amp line is really something to hear also. Tell him Dana sent you and he will charge you double :lol:
drhulsey
Post by drhulsey »
UR12 wrote: ... Anthony makes some killer cabs!
And Dana fills 'em with kick a$$ amps 8) And he ain't no slouch with the Tolex :!: :D
Tim
UR12
Post by UR12 »
:lol: :lol: I had to learn to get good with the Tolex because that is what I use to hide my poor carpentry skills :lol: :lol: :lol:
Tubetwang
Post by Tubetwang »
Good shoe!!
