Dumble #040 - guess what ? no trim pot - what values??
bluesfendermanblues
Post by bluesfendermanblues »
Hey you'all
There's a lot of rave about the #124 amp, which was photo doc'ed in great detail, but what about the #040 that doesn't even have a pre OD trim pot.
Any opinions on this construction and what pre OD values did HAD use?
http://personalpages.manchester.ac.uk/s ... 20%230040/
Bob-I
Re: Dumble #040 - guess what ? no trim pot - what values??
Post by Bob-I »
With these pics you should be able to read the color codes. I'd do it but I'm colorblind.
Also search for "Understanding the OD entrance". There was a good thread on this a year or so ago.
butwhatif
Post by butwhatif »
The trim is fixed at 33k to ground from what i can make of it--
ic-racer
Post by ic-racer »
I think this is the thread. Way back on page 37: https://tubeamparchive.com/viewtopic.php?t=400
I think the schematic (except for the OD entrance) would be similar to the "70s Schematic" http://www.schematicheaven.com/dumble.htm
oldmacman
Post by oldmacman »
Use the 100k trimmer and 220k resistor. It sounds much better.
Ben
Interesting.
I wonder what year this amp was built?
Notice how the bypass R/C layout is different from the later ones.
Good shots of V1 and V2 lead dress.
Thanks!
[img:640:480]http://personalpages.manchester.ac.uk/s ... ges/19.jpg[/img]
butwhatif
Post by butwhatif »
here's a closeup of the od in/out, only one resistor behind the cap that can't be identified-- also the od cat's and pr's have been modded for more gain-
hard to say who did it--
Is that pic from #40?
It doesn't look like this board from #40
[img:640:480]http://personalpages.manchester.ac.uk/s ... ges/12.jpg[/img]
butwhatif
Post by butwhatif »
of course not, but from the same batch i believe
bluesfendermanblues
It is supposed to be #040
check the link and click the #040 folder :wink:
http://personalpages.manchester.ac.uk/s ... ey/dumble/
