ic-racer wrote:Thanks for sharing your experience with your amps. The first post listed the specs of the HRM amp, but how about the specs on the non-HRM/100K amp?
I have been trying to read all your old posts on 100k, as I have been experimenting with it in my Fender conversion. You know where this is leading...I am on the brink of converting my #124 clone over to full 100k specs.
I suspect I have posted all the values at some point or another.  Off the top of my head, here it is:
1. Start with the schematic for ODS 124
2. I use a 100K pre OD trimmer (VS 350K trimmer)
3. I did not include the "brightness network" (220K//250pF) in the FX loop
4. I used a 30pF brightness cap on the amp's master volume, not 15pF
5. I used a 100KL "level" pot, not 250KA
6. I put a treble gate/tone control at the output of the OD, from the input of the 100KL "Ratio" control to ground.  It has a 1,000pF cap in series with a trimmer (variable resistor).  Setting is around 150K to ground or so
7. I use 5.1K grid stopper resistors and 1K 5W screed grid resistors on the power tubes
8. I use EL34s in this amp, at least at the moment
9. I use Marshall-style iron in my amp
I think that covers everything.  Basically, this is a standard Skyliner amp with 100K plate load resistors
Gil
