Just curious what the effect would be of raising the values of the V2 snubbers vs lower values. What would I expect to hear? I raised mine from 270pf to 330pf and recorded cilps with each value, but am having a hard time quantifying the difference because my recording technique is pretty rudamentary (to say the least) and the mic position may have changed between the two recordings.
Thanks,
mark.
higher/lower pf V2 snubber values - what's the effect?
"...there are flying v's and then there are the ones shaped like peanuts..." - my son at age 9
Malin Amplification - Boutique Amps
www.facebook.com/MalinAmplification
@MalinAmps
@MalinAmps
Re: higher/lower pf V2 snubber values - what's the effect?
Well the difference is pretty subtle. I'm not surprised you're having trouble telling the difference without a well controlled environement.
The 330s will provide slightly more treble bleed than the 270s. Here's a simulation plot of the response curve of each. The lower curve is the 330pF snubbers.
Thanks for the plots!odourboy wrote:Well the difference is pretty subtle. I'm not surprised you're having trouble telling the difference without a well controlled environement.
So when you say trebble bleed, it is bleeding trebble across the plate -> cathode and being filtered it out of the signal (i.e. that is what causes less trebble to the output - and to the ear)?
Mark.
@MalinAmps
@MalinAmps
The snubbers go from plate to cathode which is at ground.
It (higher cap value) is bleeding treble from the signal.
Higher cap value = less treble.
Odourboy's graph shows the 330pf cap as being lower than the 270pf.
Got it. Thanks, guys.Stanz wrote:It (higher cap value) is bleeding treble from the signal.
Mark.
@MalinAmps
@MalinAmps
