Bob, a few thoughts for your consideration:BobW wrote:Here's a few pics of my 124 (+/-) build. thanks to Funk for the great looking chassis.
I don't like the results of the cloth wire w/no wax (pic 4) so, I may change over to teflon.
1. It seems you mostly use Xicon MF resistors. You may want to mix and match as those tend to sound pretty toneless if used top to bottom.
2. The slope resistor should definitely be either CF or a nice MF type.
3. I believe I have only seen one amp where the cathode resistors were NOT MF. You use CF in your amp.
4. I would consider losing the cloth covered wire now, before you go much further and kick yourself for not having done it sooner. It is so easy to use, cut and push back... but if you start making changes to the amp, it will look like shyte real quickly. BTW, vintage cloth covered wire was fine, but what is available nowadays is no good. I don't believe it's wax or lack thereof either, the material just seems to be looser.
Gil
