Dumble Tweedle Dee like output stage and power supply question.
Post by Mark »
I have a 5E3 amp to service and it’s one of those amps that is a culmination of mods. (All the parts are of good quality, such as Mercury Magnetics transformers and boutique caps.)
It uses a 12AX7 in lieu of the 12AY7, one of the preamp coupling caps is an 0.047uF, the P.I. stage uses the Paul C mod.
https://ampgarage.com/forum/viewtopic.php?f=8&t=38295
The power supply is different too, the amp uses a new production Tunsol 5AR4, 30uF first filter cap, a choke in lieu of a 4.7K or 5K choke resistor. There are no screen grid resistors.
I decided to start with checking the bias of the output JJ 6V6’s I thought the extra voltage from the 5AR4 coupled with the 250 ohm 8 watt Ohmite cathode bias resistor (measures 251 ohms) might mean the output valves are biased too hot.
I measured the mains voltage and it was measuring 239vac (opposed to 240vac Australian). The B+ voltage are:
B+1 = 419VDC , B+2 = 419VDC, and B+3 = 309VDC.
The voltage across the cathode resistor is 26.23VDC
The current flow through the two 6V6’s is 53.8mA and 48.7mA respectively. This is just nuts, the maximum current should be 35.5mA’s.
The percentage dissipation of the first 6V6 is 151% of the maximum valve and the second one is 137%, I don’t think this is a good environment in an output stage.
I tried putting a NOS 5Y3 rectifier in and the power supply nodes measured: B+1 = 373VDC, B+2 = 370VDC, B+3 = 274VDC.
The voltage across the cathode bias resistor is 23VDC. The current flow through the valves is 47mA’s and 43mA’s. Given the maximum current flow is 40mA’s, this means the plate dissipation is 117% and 107% respectively.
This seems a far better situation than the Dumble Tweedle Dee setup which I really question the value of at this point.
I did try simply increasing the cathode resistor value till the output valves were within acceptable current flow, however I needed a 802 ohm resistor and the rail voltage was now 462VDC which would exceed the voltage rating of 6V6 valves.
At this point I’m not seeing the value of the Dumble Tweedle Dee like power supply/output stage. I’m inclined to use a 5Y3, reduce the first filter cap to 20uF, increase the size of the cathode bias resistor, and use 1K screen grid resistors.
My question is have I missed something or is my logic sound?
Thanks for your assistance.
Yours Sincerely
Mark Abbott
sluckey
Re: Dumble Tweedle Dee like output stage and power supply question.
Post by sluckey »
Lower the screen voltage to bring the current down.
Post by Mark »
sluckey wrote: Thu Oct 02, 2025 4:22 am Lower the screen voltage to bring the current down.
Thanks for your advice I will give it a try and report back.
Yours Sincerely
Mark Abbott
