FX Loop Advice for Hot Cat with VVR Build
bcmatt
Re: FX Loop Advice for Hot Cat with VVR Build
Post by bcmatt »
pdf64 wrote: Thu Jul 10, 2025 1:32 pm See limiting values p5
https://frank.pocnet.net/sheets/010/e/ECC83.pdf
Thanks for the link and page number. I've learned something new. So the max cathode to heater voltage on a 12ax7 is 180V.
So now with my changes it's about 120V difference (177V-58V). That seems better.
Anything else look out of wack?
lonote
Post by lonote »
Thinking 58V elevation is right in the zone. I seem to recall Merlin suggesting 30V-60V.
bcmatt wrote: Thu Jul 10, 2025 4:59 pm So the max cathode to heater voltage on a 12ax7 is 180V.
Not always. Some are rated as low as 100V and some as high as 200V, and the positive and negative limits may be different.
bcmatt
Post by bcmatt »
martin manning wrote: Thu Jul 10, 2025 6:12 pm
Oh, interesting. I guess I shouldn't assume. I should check what I have in that position. I popped a somewhat modern (less than 20 years old or so) Tung-Sol in the loop position. I just have a box of preamp tubes with varying levels of labels still visible. That one's label was still bold and clear, so it earned a spot in an amp.
pdf64
Post by pdf64 »
martin manning wrote: Thu Jul 10, 2025 6:12 pm ... Some are rated as low as 100V and some as high as 200V, and the positive and negative limits may be different.
I get the impression that the h-k limit is 180V design centre, 200V design maximum
https://frank.pocnet.net/sheets/093/1/12AX7.pdf
https://frank.pocnet.net/sheets/093/1/12AX7A.pdf
You may be correct Pete, but IDK what the current manufacturers are doing with respect to quality control.
A look at the current 12AX7 Vh-k specs as published:
JJ Electronic 180 "Limiting Value"
New Sensor +100/-200 "Not More Than"
PSVane 180V "Limiting"
