The amp cosmetically looks clean as a whistle. Inside some of the electrolytics have been replaced everything else is original including the speakers. Almost looks like it has never been used.
the amp is a little noisy and I am picking up some radio stations and unfortunately the music selection is not that great.
Using a better guitar cable helps and the radio station volume changes when I touch the metal component of end of the guitar cable. When teh cable is not plugged in and the volume is cranked no radio station. Tubes are slightly microphonic especially when tapping the vibrato knob control.
few questions:
1) would placing a .01 uf cap between the ring connection in the jack to the chassis help as there are 4 inputs I would need 4 caps? I added a ferrite collar around the power cord near the entrance to the amp that didn't seem to help. was also recommended placing a 47pF cap between ring and sleeve see my post below as I am editing this. Also chatGpt suggested another mod see post response below.
2) the tubes are not shielded on this amp would wrapping tin foil around them help or just shorten the life of the tubes from heat. Or any better ideas?
3) the original wiring to the speakers seems very flimsy the wires connect to the transformer through a little terminal board. It is surprising how thin the wires are to the speakers
if I change the wire to thicker wire will it decrease value of the amp?
4) the speakers are the originals, they seem to function well although given their age might a new pair of 10" alnico sound better such as the Celestian G10 gold 16ohm? Plus this would allow me to remove the speakers and store them to protect them in case I sell the amp someday.
Overall, I am having some buyers remorse as the amp was $$$ as it was so clean. I did not get a chance to play it much before buying it. The amp seems a little "closed" sounding if that makes any sense? I have a vintage 1972 Princeton I was comparing it with and I know it's a whole different ball game but the Vox seemed a little less open sounding? Definitely a more compressed sound. This is my first Vox I was looking for a vintage ac-30 yet found this and didn't want to miss the chance to own a vintage Vox
Any other suggestions welcome!
