This is a post-job report, just FYI, because this was something I had never encountered. DUT was a Carvin Nomad 112 in very good condition. Tubes would not light up. Heater voltage was present, but very low. I pulled all tubes out, and voltage was good at 6.4vAC. As soon as I would plug in one or two preamp tubes, voltage would sag under 6 volts. Measurements were erratic.
I pulled the heater winding from the PCB. (Fast on connectors! This is a clue for later!) Winding voltage read nominal. I clipped in a 4.3R resistor, drawing over an amp, and voltage remained OK at about 6.3v.
I pulled the main PCB, retouched some solder points, but everything looked OK. When I pulled the heater's fast-on connector, I noticed some heat damage (browning) on the plastic safety sleeve of the fast-on, and I noticed the connection was a bit loose. Ah ha! So I painted all the connectors with DeOxIt, retensioned the fast-on, and reassembled everything. ALL GOOD.
So that one connection was a bit loose, expressed as heat, and making the voltage unstable.
Mystery sagging heater voltage SOLVED
drewspriggs
2 others liked this
Re: Mystery sagging heater voltage SOLVED
Do you mean those little crimp connectors that join to a spade? I found the biggest issue with those is people use either a pair of pliers or really shitty crimpers to join them onto wire, which can cause heat build up/joint expansion over time that loosens.xtian wrote: ↑Thu Mar 06, 2025 1:51 am This is a post-job report, just FYI, because this was something I had never encountered. DUT was a Carvin Nomad 112 in very good condition. Tubes would not light up. Heater voltage was present, but very low. I pulled all tubes out, and voltage was good at 6.4vAC. As soon as I would plug in one or two preamp tubes, voltage would sag under 6 volts. Measurements were erratic.
Using them in automotive stuff, once they were crimped we'd slide the insulator off, fill them full of solder, then put the insulator back on - seemed to reduce the rate of them failing significantly.
This is a Carvin amp, and their build quality is good. The crimp to wire was solid. It just had a loose grip on the spade.
I've seen similar things in many amps, sometimes the scorch marks are way more apparent. These days I default to clipping the press on bit and soldering wires direct to the board or a tube socket. Makes it slightly more annoying to work on, but should be way more reliable if done right. Probably fine to retention, but I worry about metal fatigue. I wonder what the current rating and how many connect/disconnect cycles most of those are rated for.
Edit: to be clear, I only think this is necessary for heaters due to the high current. I've seen this failure most often in higher powered amps.
I got curious and looked for datasheets. Couldn't find any info on number of connection cycles or current rating, and only some have a voltage rating.
