I'm working on a build and having some tremolo issues. The details of the build are:
- AB165 Bassman preamp. Normal channel only.
- ECL84 push-pull power amp. I'm taking a lot of inspiration from the SoLow Watt project here, among others. I've built a few amps with this power section and find them to sound great and be perfect for home/apartment amp usage.
- Added Tremolo. Specifically bias wiggle tremolo on the preamp. This part I basically lifted directly from an AA764 Vibro-Champ
- Added Reverb. This is a pretty standard Fender reverb circuit. I borrowed from the AB763 Vibroverb here but its essentially the same in many Fender amps.
Schematic with voltages below. Full size version here.
