Hi, since the NKK Imp switch is no longer avail, is it just the switch over at AE that makes the best sense? Other options?
Thanks A
						Impedance switch
- dorrisant
		Re: Impedance switch
That is the one I switched to... Pun intended.
Yes that's the one, and only. I see that's Tube Depot actually has a few NKK still avail.
Thanks - time to stock up.
- johnnyreece
It's not as pretty, but I've used these with success:
https://www.taydaelectronics.com/electr ... -2684.html
I just tie the three poles together. See the attached layout for an illustration. For $1.09, it's hard to beat. Of course, this is a four position switch (which is what I required). They do have three position switches, as well.
You've never burned one of those switches up ? How many Watts have you put through one at 4 Ohms ?
						- johnnyreece
Nothing more powerful than a JTM 45, and  never at 4 ohm (my cabs are 8 and 16).  I don't do very high powered amps.  Tightwad here.
If you like spending more money and like the flush look, here's another option at a little over $15: https://www.mouser.com/ProductDetail/Sc ... NCShAlI%3D
				SoulFetish
I use these for my voltage and impedance selectors. I like them. I think these are Schurter's updated versions of the Marshall style voltage and impedance selectors. Although, last I checked, they still sold the old Marshall style switches.johnnyreece wrote: ↑Fri Sep 06, 2024 1:07 pm Nothing more powerful than a JTM 45, and never at 4 ohm (my cabs are 8 and 16). I don't do very high powered amps. Tightwad here.
Very solid piece, thanks for the intel.
A
						A
