Bell & Howell
Bell & Howell
Are B&H schems commonly available.?
Looking for a Filmosound 138 M-2.
Anybody know where i can get one.?
I have found a few, but not this model
Thank You
Thank You
Re: Bell & Howell
There very simple tube circuits, what's the issue with it?
sluckey
Re: Bell & Howell
Here you go. Turn to page 95...
Re: Bell & Howell
Just making sure i abandoned all the stuff for the audio reader.
Thanks for the great link
sluckey
2 others liked this
Re: Bell & Howell
That filmosound pdf is worth saving. I have extracted and stitched the 138-M schematic together for quicker access.
Re: Bell & Howell
Yes.... thanks.
Stuff is really CRAMMED in here.
I was thinking the audio amplifying part could probably be used as is for starts, so i was trying not to pull it all out and start over, unless i saw something really strange........ 1M grid stops and 68k grid leaks.
Thanks again for your help.
Re: Bell & Howell
I wouldn't trust too much in there. Playing on a current limiter and/or lowering the fuse to 1A might be a good idea. I don't think the giant, hermetically sealed, steel electrolytic cans visibly leak but they do go bad. Same with most of the coupling caps. I always start over on B&H stuff, aside from the standalone power amps that aren't so crowded inside.
sluckey
2 others liked this
Re: Bell & Howell
I got lucky. Just did a search for "filmosound" on Hoffman's forum and quickly turned up this topic with the web link for that pdf.
https://el34world.com/Forum/index.php?t ... 4#msg47394
Re: Bell & Howell
Yeah, it is a mess in there.maxkracht wrote: ↑Fri Jun 14, 2024 6:29 pm I wouldn't trust too much in there. Playing on a current limiter and/or lowering the fuse to 1A might be a good idea. I don't think the giant, hermetically sealed, steel electrolytic cans visibly leak but they do go bad. Same with most of the coupling caps. I always start over on B&H stuff, aside from the standalone power amps that aren't so crowded inside.
The chassis is about 10x4 inches and just packed with stuff.
Would be better to just gut it and build something simple.
It is a single 6l6.
It is a metal case 6L6, i am assuming one of the earliest iterations with the lower power dissipation
Re: Bell & Howell
Yes, those only had a 19 watt rated plate and said to be good only up to 360 volts and 270 or so on the screen.
Re: Bell & Howell
Note that the 6L6 {nothing} has the metal shell connected to pin 1 on the socket. Don't use that socket terminal as a tie-point, ground it so you don't create a shock hazard.
Re: Bell & Howell
I got the projector, speaker cab and some 16mm movies at a garage sale for 40 USD.
Had i known more..... or anything ..... about these amps i may not have bought it.
I thought it was a 2x 6V6 with a AlNiCo speaker.
It has a fiield coil speaker, not even sure if it is good, or good for guitar.
So i am just going to gut this thing, and measure the OT to see what it really is.
I have not checked the DCR of the speaker, but that may not tell the whole tale of the OT.
This will be more work than anticipated.
The speaker cab IS Pretty Cool though
Re: Bell & Howell
As long as the paper isn't too rotten there's a good chance the speaker is still fine. I doubt anyone was abusing it too much. $40 and a few hours work for a funky looking Champ isn't bad. If you take the amp apart, be careful with solvents around the paint. Seems like anything more than soapy water will take the paint off and there's always some mystery
1940's goo that will also remove the paint. Just leave the goo alone unless you plan to refinish.
