Colgan’s SSS without reverb
Eges
Post by Eges »
Hello, I want to build Colgan’s Steel String Singer but without reverb. Would it affect the tone of the amp? And also what would schematic look like when reverb circuit and tubes (v3,v4,v5) removed?
timrobertson100
Re: Colgan’s SSS without reverb
Post by timrobertson100 »
Hi Eges, and welcome
There is always going to be some tone difference if you modify a circuit, but I would expect it could be designed in a way to be negligible in an SSS given its a clean amp.
Before trying to answer the questions I think it might help to learn what specifically it is about the SSS #2 (I guess?) you want to capture. It has a post phase inverter cathode follower, which is not super common for example. You could try and include that, but an alternative might be to marry a similar preamp / tone stack to a more typical power amp arrangement.
I think you may get better advice here if you could elaborate on your hopes for the amp.
Please also see the current excellent thread in the Dumble files section, documenting a cleaned up schematic. (Edited to add) You can actually see what the schematic would be removing the reverb very clearly on that post. It’s an excellent diagram.
ElectronAvalanche
Post by ElectronAvalanche »
Hi Eges,
I built a 002 clone without the reverb section but with an internal Dumbleator FX loop back in 2014. It sounds great.
Here is the schematic I recently upadated with the bipolar bias circuit as per Martin Manning.
Hope this helps.
Best,
Electron
Eges
Post by Eges »
Thank you so much! Starting to build it!
Eges
Post by Eges »
timrobertson100 wrote: Sat Feb 10, 2024 4:08 pm Hi Eges, and welcome
I'm including CF, my concern was keeping it as clean as possible. So removing reverb wont increase the gain right?
timrobertson100
Correct - the reverb path gets tapped off early, and then mixed back in at those two 220k resistors. When the reverb return pot is down (i.e. no reverb) there is no signal to mix back in. By omitting the reverb section you’ll be doing the same - like electron confirms in his build above (only one 220k resistor before master).
Good luck - my Colgan/Erwin SSS build is my favourite amp.
Eges
Post by Eges »
timrobertson100 wrote: Tue Feb 13, 2024 12:49 pm Correct - the reverb path gets tapped off early, and then mixed back in at those two 220k resistors. When the reverb return pot is down (i.e. no reverb) there is no signal to mix back in. By omitting the reverb section you’ll be doing the same - like electron confirms in his build above (only one 220k resistor before master).
Thank you so much, I hope you can look around to my other thread too :)
timrobertson100
I am really curious how this build turns out.
I’ve recently discovered the Phillip Sayce amp (Mother) built by a member here, which I gather should be something like an SSS or Dumbleland with the CF (based on comments I could piece together). It sounds immense.
Please keep us posted on the results.
Lothy
Post by Lothy »
I just finished my #002. I must say, if you leave the reverb out, you miss a big highlight of this amp. The reverb is one of the best I've ever heard in an amp.
But I'm a reverb hound and if you're not, leave it out. :D
Cheers
Gerhard
Eges
Post by Eges »
It’s in the building process. I’ll update you guys :)
Eges
Post by Eges »
Hey guys, should I change anything on the amp when I'm converting it to 6v6's 20 wattish area(Like AN's Steel String Sultan)? Using deluxe or princeton reverb iron wouldn't be a problem right?
Eges
Post by Eges »
One last thing guys, did I implement the mid boost right or should I change it?
Edit: Nevermind I placed it wrongly on feedback loop. Should be on treble cap
Eges
Post by Eges »
It’s coming alive :) Had to try 3 different chasis’ but now it is done. It’ll be completed in 2-3 weeks at max.
Eges
Post by Eges »
I want to experiment with different pi/cf tube configirations when the amp is up and running. Do I need to change anything when swapping from 12ax7/12ax7 to 12au7/12bh7 in PI/CF section?
Eges
Post by Eges »
Here is how the amp sounds, really punchy and surely nails SRV. The clip starts clean and then I added Kingtone Duellist for lead part. Weird but preamp feels gainy I’ve ordered 2 5157’s so maybe it will be better that way, right now I keep gain at around 9 o’ clock. I think it really starts to sing when master is around 4-5 atleast. Bright and Deep is on. Mid boost off, gain structure on the lowest setting. Oh forgot to say that this thing is alot and I mean alot louder than my super reverb even with 6v6’s and tiny transformers I have.
https://youtu.be/xoK-JqMrREk?si=cSuaDC4ZXF_89uSn
