I imagine I’ll be learning the basics for a long while yet, but I’m enjoying the process.
For instance: I just learned more about grid stoppers. I’d read about how they act as an LPF during my on-going research; but didn’t know about them slowing down the charging of the coupling caps - so “thanks” for that nugget
martin manning wrote: ↑Sun Dec 31, 2023 1:00 am
No sorry, keep it going from pin 1 to pin 5, just lower it to the level of the solder lugs.
Quick follow up: does it matter which end (pin 1 or 5) I connect the leads from the bias section of the main board? I suspect either way works, just wanted to double check.
Additionally - is it better to run B+ lines over or under signal lines? I want to get this correct the first time so that I don’t have to do it twice, lol.
Also; yes, I’ve constructed a simple load simulator using a 75w/8R wire-wound resistor and my DMM has probes currently. Been searching for a set of grabbers here and there when I think of it - but haven’t picked any up yet. I have a set of clip leads, but they’re only 6” long. Thought about lengthening them but wasn’t sure if that compromises the readings in any way.
Certainly open to advice on these points as well.
Thanks again!
