green-black 0.4 OHM.
yel/green-black 0.3 OHM.
Does that mean I have fried the OT
Maybe, but I am not sure your resistance measurment is reliable way to test tranny, especially since your problem is intermittent. Here is info on testing the tranny if you still think it is bad: http://www.geofex.com/ampdbug/outtrans.htmmat wrote:OT secondary wires unsoldered:
Does that mean I have fried the OTIf so what might have caused this..
I did the simple OT test and to me the readings seem to be in range.Here is info on testing the tranny if you still think it is bad: http://www.geofex.com/ampdbug/outtrans.htm
I replecaed the standby switch - no help.It does sound like something is arcing somewhere and it could be the trannies, choke, tubes, or sockets - even the standby switch. Standy is easy to check, just throw a jumper across it (CAUTION!).
With the PI tube removed = no noise. Swapped PI tube to different one = noise. Changed the .1uF PI couplers to fresh Xicons, still got the noise in there..If your master vol is down and you still hear it then it does seem like the problem is near the output section but it could be the power supply. Try removing the PI tube and let it run. If it goes away, look for DC getting past the plate couplers on the PI or a bad PI tube.
Its good news that the noise is gone without the PI as the problem is most likely back in the pre-amp although it is not 100% because you now also have removed negative feedback and you can't rule out some bad caps, resistors in the PI section but that is unlikely.mat wrote:
dlator 383 46 257 1.91
Any further suggestios ?
I have to check the dropping resistors again but the last one is (was 86k 3W) 95K 7WTonegeek wrote:Good work. Can't wait to hear it! Are you still using 30k > 10k > 30k on your dlator dropping strings? I ask because I am thinking of changing mine since it is not deriving power in the best way. I will probably just stay with 2 caps though. The most current info I have on the dropping string for the dlator is 47k > 33K (for 2 caps). This is close to what you are using.
