What five tools have helped
angelodp
Post by angelodp »
What five tools ( perhaps beyond the usual ones, temp controlled iron, nut drivers, etc ) have made a difference in your building techniques.
v00d00blues79
Re: What five tools have helped
Post by v00d00blues79 »
Hemostats... great for hard to reach places! :D
Andy
drhulsey
Post by drhulsey »
angelodp wrote:What five tools...
Chop sticks
Dental mirror
Step drills
Air-powered file
Beginner's luck :D
Homework (pre-build planning) Oops :!: That's six :oops:
Tim
FUCHSAUDIO
ummm
Post by FUCHSAUDIO »
Hammer, Nibbler, Unibit, duct tape, silicone.
CaseyJones
Post by CaseyJones »
Torches, body grinder, English wheel, shot bag, Bridgeport. :lol:
ampdoc1
Post by ampdoc1 »
Thermal Wire Stripper ($35 on Ebay)
Drill press
Amp cradle
Variac.
sportster4eva
Post by sportster4eva »
angelodp wrote:What five tools ( perhaps beyond the usual ones, temp controlled iron, nut drivers, etc ) have made a difference in your building techniques.
Dovetail Jig
Air Stapler
Circle cutting jig
Drill press
Vega rip fence
Common Sense .... (honorable mention)
Sometimes I'm good, then I'm bad..
Andy Le Blanc
Post by Andy Le Blanc »
a good bench light
long florist pliers (rubber covered handles)
steel sponge (tip cleaner, doesn't vary the temp)
a clean bench
better than ok ventilation
lazymaryamps
Any of you guys use one of those things that sucks the solder fumes away from you and filters it?
Can't be good to breathe that stuff (lead) for extended periods.
drhulsey
Post by drhulsey »
sportster4eva wrote: ...Common Sense .... (honorable mention)
Maybe that should be #1 :!:
Andy Le Blanc wrote: ...a clean bench...
Now you're steppin' on toes :twisted:
Tim
Dai H.
Post by Dai H. »
Structo wrote:Any of you guys use one of those things that sucks the solder fumes away from you and filters it?
you can build a cheapskate version. Just get some filters (for a manufactured version fume filter) and a fan and a power supply (AC adaptor, etc.). Doesn't get 100% of the fumes but it's a lot better than nothing.
v846
Post by v846 »
Dental pick, I use em to bend leads to form around turrets
long nose pliers
good wire cutters
heat sinks
fans for extracting fumes
Tonegeek
Post by Tonegeek »
curved needle nose pliers
dental pick (good for hooking wire when desoldering)
strong lighting
full scale layouts (glue stick to work, drill, soak to remove)
good ears!
Pitcher Amplification
http://pitcheramps.com
LOUDthud
Post by LOUDthud »
Small boxer type fan in a small box with fuse and switch. Good for blowing fumes or cooling amps while running them at full power.
Thermal wire stripper. Great for use on teflon wire. Remove the insulation without nicking the wire.
Needle nose pliers with smooth jaws. They don't leave marks on wires.
Strain relief pliers. Get those darn things in and out with ease. Not cheap.
Small variac to run soldering iron(s).
