Could you share that datasheet?
I've been painting by numbers for too long
Greater resistance = more compression. One of the more desirable traits of guitar amps is their ability to articulate the thing we call "touch sensitivity". Dumble's amps are very good in this regard in my experience. Touch sensitivity also manifests itself as a greater dynamic range and - for want of a better word - transparency. Transparency of detail, such that there is a sufficiently audible difference between the uncompressed non-linear tube amp and the compressed linear solid-state amp. Compression can be added later with a good pedal if needed, but the articulation, touch sensitivity, transparency whatever we call it, should be there... to begin with.The stopper provides current limiting and compression... Since in reality the screen current will not quite attain this value we should use the next highest standard resistor, which is 470 ohms for a wire-wound, although 1k is more common and will cause the characteristics to compress more.
 1k
  1kI went over my biasing figures again and taking:
It's easy to see that a transformer that exhibits a voltage and current ratio of 20 will have an impedance ratio of 400. This means that connecting a speaker of 8 ohms to the secondary will reflect an impedance of 3.2k to the primary. Doubling the speaker impedance to 16 ohms would also double the primary to 6.4k. (This is a useful trick that may allow you to obtain your ideal primary impedance by connecting the transformer to a speaker impedance other than the rated value.)
Thank you for those. The Mullard datasheet is the one I've been using. I thought the "vintage" Telefunken datasheet you referred to might have had some extra pages of sample schematic pages but its basically the same as the Mullard datasheet, except in German! I have trouble enough with English so I will stick with the Mullard datasheet but it is now easy enough to compare it with the Telefunken data.bepone wrote: ↑Sun May 21, 2023 7:35 pm a lot of nice informations can be read from this 2 datasheets
https://frank.pocnet.net/sheets/129/e/EL34.pdf
https://frank.pocnet.net/sheets/128/e/EL34.pdf
 i made mistake bifore , it is not 470R , something between 290-350 ohms will be..Stephen1966 wrote: ↑Sun May 21, 2023 8:35 pm Biasing
- Vgk = -22V
not really, doing it all days.. 30 min job..Stephen1966 wrote: ↑Sat May 20, 2023 7:11 pm That aside, drawing up the load lines for this circuit has been a PIA. Is drawing loadlines becoming a lost art?
Vgk = 22V, (-22) it comes from the mutual characteristics chart.bepone wrote: ↑Sun May 21, 2023 10:12 pmi made mistake bifore , it is not 470R , something between 290-350 ohms will be..Stephen1966 wrote: ↑Sun May 21, 2023 8:35 pm Biasing
- Vgk = -22V
from where did you get -22V?
I was thinking of using interpolation (blend) tools in Illustrator. Are you going to spill the beans and tell us how you do it?bepone wrote: ↑Sun May 21, 2023 10:18 pmnot really, doing it all days.. 30 min job..Stephen1966 wrote: ↑Sat May 20, 2023 7:11 pm That aside, drawing up the load lines for this circuit has been a PIA. Is drawing loadlines becoming a lost art?
the real PIA job is to recreate curves which are not existing in any datasheet, and you need them.. and ofcourse it is possible
if this is your graph to follow , then Ug=-26VStephen1966 wrote: ↑Mon May 22, 2023 7:48 am from where did you get -22V?
No the other graph. Blue dot. Va after the screen-grid dropper and screen grid stopper voltages are subtracted.bepone wrote: ↑Mon May 22, 2023 7:59 amif this is your graph to follow , then Ug=-26VStephen1966 wrote: ↑Mon May 22, 2023 7:48 am from where did you get -22V?
your graph to follow is PINK graph.. and blue dot on it is ok.. trick in single ended amps is that they "recreate" voltage supply which doesnt exist..because of inductance behaviour during the change. so your 350VDC will have peak at 680VDC.. how this is possible? because inductance of transformer makes the other "not existing" part.Stephen1966 wrote: ↑Mon May 22, 2023 8:04 am No the other graph. Blue dot. Va after the screen-grid dropper and screen grid stopper voltages are subtracted.
ok i need to find some timeStephen1966 wrote: ↑Mon May 22, 2023 7:54 am I was thinking of using interpolation (blend) tools in Illustrator. Are you going to spill the beans and tell us how you do it?
