Cathode follower for compression
Tobyk
Post by Tobyk »
Did anyone try the Merlin Blencowe cathode follower setup (say 100K Rk and 47K Ck) for added compression, and if so, how did you like it?
10thTx
Re: Cathode follower for compression
Post by 10thTx »
Link to what you're referring to, please?
with respect, 10thtx
roberto
Post by roberto »
I'm not sure we are talking about the same mod because I'm not familiar with the specific reference, but I modded some Bassman in the past by lowering the cathode follower resistor from 100k to 47 to 68k depending on the taste of the owner of the amp. It was switchable with the amp not running (because of the BUMP).
It helps to get a more compressed sound at lower volumes, but then if you play at higher volumes you need to switch back to 100k.
Tobyk
Post by Tobyk »
10thTx wrote: Thu Dec 29, 2022 12:52 pm Link to what you're referring to, please?
Tobyk
Post by Tobyk »
roberto wrote: Thu Dec 29, 2022 1:36 pm I'm not sure we are talking about the same mod because I'm not familiar with the specific reference, but I modded some Bassman in the past by lowering the cathode follower resistor from 100k to 47 to 68k depending on the taste of the owner of the amp. It was switchable with the amp not running (because of the BUMP).
Thanks, why back to 100K at higher volumes?
Ten Over
Post by Ten Over »
Tobyk wrote: Thu Dec 29, 2022 11:10 am Did anyone try the Merlin Blencowe cathode follower setup (say 100K Rk and 47K Ck) for added compression, and if so, how did you like it?
What is "Ck"?
Tobyk
Post by Tobyk »
Ten Over wrote: Thu Dec 29, 2022 4:13 pm
What is "Ck"?
Sorry, ment to say 100K Rp and 47K Rk..
Encom
Post by Encom »
I have it on a switch. I find it most helpful when recording clean parts. The bass notes don’t pop out as much and everything is more even. I don't really use it with distortion as it softens the transients and I prefer more of a punchy sound.
old user username was steveo
Tobyk
Post by Tobyk »
Encom wrote: Fri Dec 30, 2022 5:13 am I have it on a switch. I find it most helpful when recording clean parts. The bass notes don’t pop out as much and everything is more even. I don't really use it with distortion as it softens the transients and I prefer more of a punchy sound.
Thanks, good to know!
roberto
Post by roberto »
Tobyk wrote: Thu Dec 29, 2022 3:00 pmThanks, why back to 100K at higher volumes?
What you do by lowering the 100k to 47k is exacerbate the compression of the stage at lower volumes.
When you crank the volume, you will find too much compression, and need to go back to 100k (or at least increase this value).
Please note that this is valid for that specific configuration of dc coupled stage to the cathode follower.
Different polarizations of the gain stage could and will work better with different values.
I used once, for an high gain lead, a 220k 1k to 47k stage and it was working pretty well.
Tobyk
Post by Tobyk »
roberto wrote: Fri Dec 30, 2022 7:09 pm
Thanks for explaining.
ViperDoc
Post by ViperDoc »
I put a DCCF into a Tweed HP Twin. The added compression was very noticeable. I ended up taking it out.
EDIT: By that I mean Blencoe’s series 10K/1N4007 from grid:cathode and lowered Rk value.
Just plug it in, man.
Tobyk
Post by Tobyk »
Does anybody know if this ’Direct DC coupled cathode follower’ setup for compression can be done with transistors instead, with the same compression result? That is, ’direct DC coupled emitter follower’.
Was thinking of trying this for a pedal..
I don't know how similar the effect would be, but I'd guess that a JFET source follower would be a better bet.
Tobyk
Post by Tobyk »
I think that’s the correct answer, thank you! JFETs seems to be quite similar to triodes.
