Since I haven't found cap with exat value , if I use a voltage more high that required is a problem?
Example:    10uF 50V  instead of 10uF 25V
                  4,7uF 100V  instead of  5uF 25V
						Voltage Cap?
Re: Voltage Cap?
For electrolytic capacitors like you describe, that is fine and in many ways somewhat preferable.  The only place where I have noticed a clear difference is between a 1,000V ceramic cap and a 50V ceramic cap of the same value (47 picofarads) in the bright switch on my amp.  So I think it might make a difference for some capacitors that are passing audio signal, but not for the most part.
									-g
