Hi, I am looking for vintage style connectors that were used on the old B&H Jensen speakers. I need either a made up cable or the male and female connectors.
If you happen to know where to source these items.
						Jenson B&H connector
		Re: Jenson B&H connector
Why don’t you use modern Speakon connectors?
Why does it have to those?
To keep it original for now, I want to convert one end to a 1/4" jack.
You will need to look at military electronics surplus sites to find that , or many some of the radio electronics sites that have a chat board you could post  a  question and picture up on.
				thetragichero
i too would suggest speakon (or one of those speakon jacks with a 1/4" jack inside if you can find it), but this site may have what you're looking for: https://www.surplussales.com/
Thanks for the intel.
A
						A
These are somewhat similar. If it’s one with the weird plug directly on the speaker, it might be a decent replacement.
https://www.taydaelectronics.com/2-pins ... -gx16.html
There’s a 12mm version as well.
