thinkingchicken wrote: ↑Sun Oct 02, 2022 3:54 pm
Just wanna hear a comparison of distortion sounds between high gain tube amps for example those with peak decibel gain beyond 110 dB like JVM410, EVH, Megalith Beta, etc. and high gain solid-state amps, preferably with comparable peak decibel gain.
I think that if you had asked your original question that way, you might have received responses pointing to examples of distortion.
IOW, preferably, solid-state amps that use no clipping diodes at all but just raw gain to achieve clipping.
Why no diode clipping? Is there a particular reason other than what you've read on the internet?
Generally, tube amps sound pleasant while solid-state amps and pedals tend to sound harsh. For example, compare the tube tone of Matthias Jabs from the Scorpions with the solid-state guitar tone of Dimebag.
That is the perceived internet wisdom. Like most internet "wisdom", it is not necessarily so. There has been a great deal of work on making pedals sound not-harsh, and some solid state amps that are difficult to distinguish from tube amps by listening. Can you prove that statement by measurement, or is it only by what you heard on the internet?
Is there a difference between solid-state noise generators and tube noise generators like those from Metasonix? Perhaps, tube-based noise generators have less pronounced high frequencies compare to the solid-state noise generators.
It's difficult to make noise generators of the high-gain type be consistent from one unit to the next, let alone in a different technology. It's even harder to make accurate statements about the general sound of noise generators.
But let's think more philosophically. You're stating a bias against solid state. Can a solid state amp >ever< produce good guitar sound?  I've had long discussions on this from people whose mantra was "you can't get tone from a stone". Are you in that camp? Can a tube amp's sound be recorded and sent through a solid state amp and still sound good (assuming it ever did in the first place)? What about a tube preamp through a solid state amplifier that (1) does or (2) does not clip?
Mark Twain
