layout differences
phsyconoodler
layout differences
Post by phsyconoodler »
I was just looking over the D'Lite layout and the Ceriatone layouts and there are some differences.The D'Lite shows the left lug of the presence pot grounded and the Ceriatone is not.
Then the two 22meg resistors on V1b are in series with the cap and the ceriatone's are on either side of the cap.
These are quite a bit different in my book,and I was wondering which one is right?
I wired my presence like the D'Lite and it does indeed work,and my two 22megs are the same as the D'Lite and again they do work.
I could just try the other way and see how it sounds I suppose,but it would be nice to know which one is better.
Crystal latice or vacuum,that is the question.
Normster
Re: layout differences
Post by Normster »
The presence control wiring on the D'Lite was my "mis-interpretation" of the Hybrid-A schematic. It does work and does add its own character to the amp, but the Ceriatone wiring is the correct way for a Dumble. The D'Lite presence was, IMHO, a "happy accident." Try it both ways, but I think you'll find the Dumble method provides more available upper frequency cut.
The 22M resistors can be done either way, but I prefer running the cap directly to the plate and putting both resistors on the grid side. You might be able to hear the difference between the two methods, but it would be too subtle to worry about, IMO.
Funkalicousgroove
Post by Funkalicousgroove »
The "Correct" Implemintation of the 22M resistors is on either side of the cap.
heisthl
Post by heisthl »
RE: LFB
Tone wise I can't hear a difference but the correct way lays out better if you're using a terminal strip at the rear of the tube, plate has22m to strip, .05 (or.047) is mounted on the strip, and 22m to grid.
The other way allows you to ground the loop so you can put it on a switch or relay. Grounding point "B" in the picture disables the loop:
www.RedPlateAmps.com
greiswig
Post by greiswig »
heisthl wrote:RE: LFB
heisthl, what is the difference between grounding that point and just creating an open between the cap and resistors? I did the latter on mine, and have a 3-way switch: open/44m/66m. It is a neat tone control, but the open position is probably several db hotter than the others.
-g
heisthl
Post by heisthl »
no pop and no volume change
greiswig
Post by greiswig »
heisthl wrote:no pop and no volume change
I don't have a pop currently, but I was hoping you'd say that about the volume change. Thanks!
-g
Funkalicousgroove
Here it is in #195
Funkalicousgroove
#124
greiswig
Post by greiswig »
I'm sorry if this is hijacking the thread, but...
Other than the switching advantage that heisthl spoke of, what particular difference does it make whether the two resistors are on either side of the cap or on only one? Does isolating the cap on both sides really sound different?
-g
phsyconoodler
I'm going to find out by trying it both ways on the next build.
Thanks for the info guys!
rutledj
Post by rutledj »
Can someone clue me in as to what exactly this feedback network does tonewise. What would be the result of removing it?
Rut
phsyconoodler
It extends the clean range of the amp before it breaks up.And it makes the amp fart out less on lower notes.I have tried it an other makes and circuits and it does indeed extend the clean headroom.
It makes the sound 'tighter' and more focused.
Andy Le Blanc
Post by Andy Le Blanc »
it looks like an anode follower
havent tried one yet
but that looks like a usefull little thing
lazymaryamps
