Vibro Champ mod - RAW on a pedal
angelodp
Post by angelodp »
Hi, I have this Vibro Champ I built a while back and was thinking it would be nice to have a boost thats RAW based. Question is - I can run a wire to the rear of the amp above the pots and to the left and around near the Trem jack. This could be under the lip of the chassis and out of the way from all other wires. I could even go with a shielded run from the 15k Mid resister. That way I have it on a boost pedal switch instead of a front panel switch, more available for a switch to lead.
Make sense? Is the shielded run a must.
Ange
sluckey
Re: Vibro Champ mod - RAW on a pedal
Post by sluckey »
Shielded cable is required inside the chassis and between the chassis and footswitch.
angelodp
Post by angelodp »
Copy thanks
angelodp
Post by angelodp »
Copy thanks. What about isolation washers for the Jack?
wpaulvogel
Post by wpaulvogel »
If you’re wanting to lift the ground to bypass the tonestack, the whole wire will be like an antenna when it’s opened and floating the tonestack. It would be much better not to run a long wire even if it was shielded. That’s my 2 cents
I know it’s not what you want. The best thing to do is to wire it with the expectation that it won’t work and see what happens. While the tonestack is active and the wire is simply grounded the resistor, it’s probably no impact but once open the antenna is present.
sluckey
Post by sluckey »
no
angelodp
Post by angelodp »
What about a multi conductor shielded wire using the shield (grounded at one end only) to stop antennae effect.
Steve you are saying that isolation washer in not necessary?
A
angelodp
Post by angelodp »
I used this method on my Rocket w/Reverb and did not have any issues.
thetragichero
Post by thetragichero »
this is best handled by a relay (maybe a vactrol?). keep inside the amp signals inside the amp or like mentioned you're asking for trouble
angelodp
Post by angelodp »
Yes, I understand not looking for noise. Its easy to try. Also found this. Clip the tail 68k.
angelodp
Post by angelodp »
No Bueno, as you said Paul, its a big antennae. The small SPST switch does work, no noise. It certainly does increase the gain and distortion of the amp. Maybe a Raw pot, small one is a better way to go.
