Thank you, for the update rootz. A good lesson for me here but alas, you are not the only one with an ageing brain. I
kinda follow these kind of discussions but I'm particularly slow on my ability to conceptualise the ideas, given that a lot of the ideas are still brand new. I really need schematics, logical paths illustrated, or layouts from which I can derive these logical pathways. I used to have a very strong sense for the mathematical when I was younger, but these days, it's my visual sense and imagination which is stronger. Which is to say, if I can see, I can understand it - at least more easily. There's no accounting for any actual lack of ability, unfortunately.
I can visualise reversed bias diodes to ground and the contexts you describe both in fault protection and normal operation. Again, a schematic or layout of some description would help but it's going to be necessary to do a fair bit of background reading to fully grasp both what you are describing, and coming up with an implementation that can be fitted in this, or any other similar amp. That said, you will see I have used flyback resistors in my relays so I have a "rudimentary understanding" of what they're doing. You've certainly done your bit with the introduction to the theory though, I thank you for that. And please, don't be deterred, if you have any similar contributions to make on anything else, please keep it coming. It means a lot to me that you guys are so patient with such a dullard as I.
I'm happy with the Fenderish no load protection in the execution of the output stage in the 124 as described, and emulated in my design as well. A little piece of mind there, because of all these things likely to go wrong, forgetting to hook up the cab is probably top of the list.
Affirmative: the schematic I found was of the Baby Huey. But "Schade feedback network/shunt feedback"
 = another addition to reading list there, for another day perhaps. I'm stumbling around in the dark on Gingertubes' resistor based protection circuit though, perhaps some pointers on where to find it? A string of resistors (contrasted with diodes that might blow out) may at least allow the show to go on.
