Benson Monarch
Re: Benson Monarch
Filter caps are 2 x 100uf/100uf
						Re: Benson Monarch
Try running it without the reverb tube and see if it still does it.
A few people have had issues but that will help narrow it down.
Craig
Thinking about my second build.
						Re: Benson Monarch
I have the reverb back as well. So will double check.cgharrison wrote: ↑Tue Sep 14, 2021 2:29 am Bumping this again - thoughts on the idea "the output buffer will not work as drawn" in the reverb section of the dizzy bird schematic, per Benson?
Thanks,
Aaron
				cgharrison
		Re: Benson Monarch
Amazing - thanks!
I think I figured out the output buffer from the pic - it looks like the 1m and 1.5k resistors are tied to a 100k, that then goes to ground.
Any reverb circuit voltages you could get would be great!
				pullshocks
Re: Benson Monarch
Hi Aaron, with a guitar plugged in and the volume knob all the way down, do you get any guitar sound coming through?  Most or all of us have run into this with our builds.
Also, what is the measurement on the PI pot?
Re: Benson Monarch
Huh? Well that is interesting... Seems the power supply has evolved.
To recap:
"Aaron's" amp: 100uf -> 1K -100uf -> 10K -> 100uf
Alex's Amp: 32uf -> 1K -> 50uf -> 11K -> 32uf (using 2x32uf can)
Refer to this page (no reverb):
https://ampgarage.com/forum/viewtopic.p ... &start=287
"Our attempt": 22uf -> 1K -> 47uf -> 4.7K -> 22uf -> 4.7K -> 22uf
Based on Chris Benson's input and Aaron's photos:
https://ampgarage.com/forum/viewtopic.p ... &start=137
5 node version: 22uf -> 1K -> 47uf -> 4.7K -> 22uf -> 2.2K -> 22uf -> 2.2K -> 22uf
Based on "our attempt," and the photo and discussion here:
https://ampgarage.com/forum/viewtopic.p ... &start=372
It's funny to look back at all the early head scratching over the power supply. Looks like just about anything will work
 Mike
				cgharrison
Dizzy Bird cap?
What’s the big filter cap in electrical tape / shrink tubing coming from the junction with the 100k load resistors?
						Re: Dizzy Bird cap?
That’s just heatshrink with wires inside, probably just to keep them together.cgharrison wrote: ↑Wed Sep 15, 2021 1:00 am What’s the big filter cap in electrical tape / shrink tubing coming from the junction with the 100k load resistors?
Thanks,
Aaron
				cgharrison
Re: Benson Monarch
It’s not another stage of filtering for the reverb section?
						Re: Benson Monarch
I think you guys may be talking about different parts. Did you see this post? I believe there's a partially built reverb in the bottom picture. Looks like a cap to me. Can't see the value though.cgharrison wrote: ↑Wed Sep 15, 2021 5:36 am It’s not another stage of filtering for the reverb section?
https://ampgarage.com/forum/viewtopic.p ... &start=355
May be helpful?
				cgharrison
Re: Benson Monarch
Thanks - I missed that pic somehow.  Looks like a large value - maybe another 100uf?
						Re: Benson Monarch
Hi Guys
I had some iron left from an old tweed build and a virgin chassis so over the weekend i gave it a shot at this amp.
Spent 1hr browsing to this thread and finally chose the eyelet approach.
It turned out quite satisfactory except for the reverb. First time i tried this concept (12dW7, cathode follower) so i don't really know what to expect.
It's just that with a medium spring (8EB2C1B) i only get a mild reverb mixed in. Very short decay.
How did you guys tweak this reverb ? Or did it turn out well with the default values ?
Would love to hear experiences.
tx R
tx R
						Re: Benson Monarch
The default values in the schematics work great:rlaak wrote: ↑Mon Sep 20, 2021 6:03 pm leftover.jpg
Hi Guys
tx R
Could you have reversed the sides of the 12DW7? The low gain side should be wired as the cathode follower and high gain side as the reverb recovery. That could do it. The reverb sounds better with the additional PS node, but it sounds great even without.
						Re: Benson Monarch
Yep. Thats it !!!! Wow  stupid
