 Anyway, I started wiring using https://www.stewmac.com/freeinfo/i-1073 ... ctions.pdf as a reference, together with pics of the real thing.
(note the board created from the pdf on the forum should ideally be a little shorter)
Now I guess I start to have an idea of what you guys can feel when completing the wiring of an amp such as an ODS, so far above the complexity of this one. This sure should be addictive...
However, the manual writes that the heater poles for the power tubes must not be inverted - that is the wire for pin #2 of V4 should go to pin #2 of V3, same for pins #7.
It was the first time I could read that...
EDIT: hosted picture on the forum
