Benson Monarch
- dorrisant
Re: Benson Monarch
Can you post the Kicad files?
Re: Benson Monarch
I have that plate resistor as 470k (yellow,purple,yellow) to pull down the voltage to 75ish volts from 260 volts with a 2.2k (red,red red) cathode resistor.T Wilcox wrote: ↑Tue May 04, 2021 10:15 pmI created this in Kicad and I think its accurate but maybe someone else can put a second set of eyes on it and verify?
There are only 3 significant changes from the original schematic
1. the power supply nodes
2 the US/UK switch wiring
3 the plate resistor on reverb return triode to 220K
Per the photo of the original amp... Mike
Re: Benson Monarch
Sure thing! Let me know if that works EDIT: Didn't work
I didn't have a rectifier object and just made this so I would stop working off the wrong schem when I built mine
I will edit my last post to reflect the 470k instead of 220k
Re: Benson Monarch
Got it ! Not sure why I have 220K, and yes my voltage there was higher than it should be. Still sounds great so I'm wondering if I'll hear much differencemikeywoll wrote: ↑Wed May 05, 2021 1:50 amI have that plate resistor as 470k (yellow,purple,yellow) to pull down the voltage to 75ish volts from 260 volts with a 2.2k (red,red red) cathode resistor.T Wilcox wrote: ↑Tue May 04, 2021 10:15 pmI created this in Kicad and I think its accurate but maybe someone else can put a second set of eyes on it and verify?
Mike
Thanks Mike
- dorrisant
Re: Benson Monarch
Come up as a blank...
Re: Benson Monarch
It says invalid file on every one but that one when I try to postdorrisant wrote: ↑Wed May 05, 2021 3:40 amCome up as a blank...![]()
PM'd you
Re: Benson Monarch
I wouldn't think there would be too much difference, maybe a little high frequency rolloff? The rp/rk ratio is similar, so I would think otherwise the stage should behave similar with regards to gain?T Wilcox wrote: ↑Wed May 05, 2021 2:19 amGot it ! Not sure why I have 220K, and yes my voltage there was higher than it should be. Still sounds great so I'm wondering if I'll hear much differencemikeywoll wrote: ↑Wed May 05, 2021 1:50 amI have that plate resistor as 470k (yellow,purple,yellow) to pull down the voltage to 75ish volts from 260 volts with a 2.2k (red,red red) cathode resistor.T Wilcox wrote: ↑Tue May 04, 2021 10:15 pm
Mike
Thanks Mike
Thank you for sharing your files!
Re: Benson Monarch
I didn't get to the footswitch tonight but when I get a chance I'll swap that resistor toomikeywoll wrote: ↑Wed May 05, 2021 4:13 amI wouldn't think there would be too much difference, maybe a little high frequency rolloff? The rp/rk ratio is similar, so I would think otherwise the stage should behave similar with regards to gain?
As far as the files, anytime man. The Kicad files dont seem to upload properly though so if you or anyone else reading this wants them PM me
- pompeiisneaks
- Site Admin
Re: Benson Monarch
There's a limited number of file types it allows. The KiCad files could be zipped as I think that .zip is... if you can give me the extension of the kicad files I can add them as an option.
Re: Benson Monarch
Suggest KiCad files probably always ought to just be zipped as several file types comprise each "project" directory.pompeiisneaks wrote: ↑Wed May 05, 2021 2:22 pm The KiCad files could be zipped as I think that .zip is...
Best .. Ian
Re: Benson Monarch
Thanks Phil, didn't think of that. I'll do the same with DIYLC files next time as wellpompeiisneaks wrote: ↑Wed May 05, 2021 2:22 pmThere's a limited number of file types it allows. The KiCad files could be zipped as I think that .zip is... if you can give me the extension of the kicad files I can add them as an option.
Ian is right there are about 4-5 files anyways
- dorrisant
Re: Benson Monarch
I went ahead and put a new OT in today... I left the mill marks. I don't think that will hurt.
I put the bottom on as well. Now for the headshell.
Re: Benson Monarch
Made the pilgrimage across town to Benson Amps and picked up my speaker today. Super friendly crew there. Even threw in a free hat.
Mike
Mike
Re: Benson Monarch
Its a little squeaky at first, I threw my looper on in the garage for a few hours and it started breaking in nicely
Let me know know if you have similar observation
Re: Benson Monarch
That's beautiful. I'm curious, did you try the variation on the power supply reported by Alex in his non-reverb monarch head? Did you run into any hum with the single PS ground?
Squeaky is relative, I guess. It definitely has less high end than the Jensen that was in there. It's a great match for the amp and a part of the sound I hear on recordings/videos of the real thing. I like the speaker with my other amps as well. If it gets better with break in, I'm only going to be happier.
Mike
