old thread
Andy Le Blanc
Re: old thread
Post by Andy Le Blanc »
dont run the amp without a speaker or some sort of load
get a large wattage resistor, say.... 4 or 8 ohm 20 to 25 watt as a load
in place of a speaker......
I got a couple 300 watt 8 ohm that use to series\parallel
4 8 16 when I need too for 50 and 100 watt amps
with a load attached .... you can check out the amp electrically
you can also feel the PT for excessive heat
if its really loud or hot something is not right
lazymaryamps
utervo
Re: old thread
Post by utervo »
No worries, I took six 47ohm/17w resistors and put them in parallel to make an 8ohm load which I am testing the system with.
Andy Le Blanc
Re: old thread
good job......
whats the voltage on the plate of your 6AQ5
thats my only real worry...following this discussion
the design-maximums are a bit lower than a 6V6
so I'll be curious of your experience...
lazymaryamps
utervo
Re: old thread
Post by utervo »
Thank for your interest and help, I'll need more... :)
Seem that nothing is getting to PSU. I'm using 5Y3GT/G, tried 4 of them, no difference. I measured the plates on the 6N1P and I get a small negative voltage. I measured around 650V between pins 4&6 without the rectifier, the heaters showed 5.5V. After having the amp for a while the filter caps had a very slight negative charge, nothing else. Heaters on the 6N1P were 6.8V, all of the tubes were glowing nicely orange. What's puzzling is that it's such simple wiring to the power supply, I have a hard time figuring out how I have managed to mess it up. Nothing weird happening, no funny smell or excessive heat anywhere. I wonder if all my rectifier tubes are busted, I bought them the same time, they are JAN RCA.
Andy Le Blanc
check the hook up and schematic of the power tranny
check for the center tap on the H.V. secondary
most rectifier tubes are pretty rugged and if you've tried more
than a couple its not that...... disconnect the rest of the power supply
in case the fault is there.... and check the rectifier with no load
it sounds like something was over looked
lazymaryamps
Andy Le Blanc
Re: old thread
Its good to post pictures...
I cant see a center tap to ground
and the power take off.....from a rectifier
is off the 5V filament .....pin 2 or 8 ....5Y3GT
lazymaryamps
utervo
Re: old thread
Post by utervo »
Indeed, I have not connected the secondary center tap (0) from the PT to ground, how very sloppy of me... The power is the white wire from pin8. I'll add the 0 to ground tomorrow, better not do first time powering this late.
utervo
Re: old thread
Post by utervo »
Connected the wire and boy do I get voltages. I wonder what effect it has that I measured these without the tubes in.
Heaters: 6,73 vac
6N1P: 438 vdc
6AQ5A: 447 vdc
How much will the tubes drop those?
utervo
Re: old thread
Post by utervo »
I wonder if my multimeter is playing tricks with me, it says it's 640VACgoing to the rectifier (without it), makes me wonder how that could be turned into even over 300VDC let alone what I am getting now.
Andy Le Blanc
Re: old thread
the measured AC across the entire high voltage secondary
is the large number your seeing
with the center tap connected.... the retifier conducts half of that at a time
your running your power supply with no load
so the filter caps charge to their highest voltage
this will drop some what with loading
what was the rating of your PT in ma.
your 6AQ5 is rated upwards to as much as 49 ma. of draw....
lazymaryamps
utervo
Re: old thread
Post by utervo »
It's 0,1A I think
This is what it says.
"230V//300-0-55-300 0,1A / 6,3V 4A / 5V 2A"
My multimeter says max 500V, perhaps it starts acting funny when it gets more.
Andy Le Blanc
Re: old thread
.1 A........100 ma.
looks like its in the ball park
I've cooked multimeters before...... hopefully its ok
even though the 6V6 and 6AQ5 are rated nearly the same
the smaller size of the 6AQ5's glass envelope it the reason
for the differnt max rateing.... it might run hot ....
it might be an issue......it might not
I messed up the wireing of the powersupply in a fender twin once....
ended up with a voltage doubler..... 700 plus volts DC
toasted the filter caps and a multimeter.... sizzle.....
lazymaryamps
utervo
Re: old thread
Post by utervo »
Tried with the tubes on and a 40W light bulb in series, seemed fine until I got this high pitched sound, like an miniature engine revving up, turned it off and on a couple of times and the sound comes back. Bulb was glowing dim, which I think is what it should.
Andy Le Blanc
Re: old thread
this happend without a speaker?
recheck the circuit from the power supply
pay attention to how you wired the OPT and how feedback is applied
you may have set up the conditions for it to oscillate
also try a turn on with the preamp tube pulled out
your lead dress might be the culprit
lazymaryamps
utervo
Re: old thread
Post by utervo »
Man it's hard to be a beginner. The sound was caused by running the amp without a load, how the hell did I drop it out of the amp's ass I don't know. Hope I didn't fry anything. :oops:
I put the load back in and it seemed to do steady at least for a couple of minutes, at least didn't sound like it's in a pot with an apple in it's mouth.
Do I have something messed up in the circuit or is the transformer and rectifier just pushing that much voltage? How do you calculate what the voltage should be after 5Y3GT/G doing it's job when I have around 650 going in?
