Anyone have ideas on how to keep Mini-toggle switches from spinning while you tighten them? I have used plenty of wrenches, pliers, just my fingers, over the years. Curious if there is a more elegant solution to this problem, especially for tight spaces. Maybe some kind of tiny clamp that pushes on the bottom of the chassis and the bottom of the switch to keep them parallel? I know getting a punch with the proper keyway so switches don't spin in the first place is probably the correct answer, but that seems like cheating...
Here's what I came up with out of stuff from the junk drawer. Works fine, but could be improved.
Mini toggle wrench ideas
sluckey
Re: Mini toggle wrench ideas
I've had good results just using a nut driver and my fingers or needle nose pliers. They're always handy when I'm inside an amp. As a bonus, I can use my fingers and needle nose for other stuff too.
Good idea. Maybe you can improve the tool with a fixed spacer on the end where you put the screw and a screw between the spacer and the piece to hold - like in:
____________________________________________________________________
spacer______________screw___________________________________mini-toggle
I'm using chopped tweezers for that kind of stuff. Rather thick ones made out of stainless steel. The shortened end makes for a better grip. Nothing as elaborated as your tool, though.
RockinRocket
I always use my fingers but I likely will try the keyhole washer that comes with the switch on next builds.
Probably just a small drill hole will do.
thetragichero
i often use the ol' knuckle buster (what my dad called a crescent wrench) if I'm not just using my fingers
Here's my second and, probably, final iteration. The screw ended up like a fixed spacer, additional hold points or pivots don't seem necessary. Just some big wide tweezers.
I realize this is pretty esoteric and wouldn't be more useful than a standard wrench on most occasions, but I have run into situations where a wrench wont fit enough times to warrant this thing. I sometimes don't have enough sense to say no when someone asks me to put switches where switches shouldn't go...
