I am a newbie to this forum and hope you guys can help me out with an issue I have.
I have a Line 6 Bogner Spider Valve 112 that produces an extremely loud and sudden Blaring noise just a few seconds when standby switch is on.
It occurs usually in the first few seconds (up to a minute) but after this it never does it again?
If you strike the top of the amp the noise will cease which suggested to me it was a bad connection on the main board.
The volume control has no control over the noise either which has me thinking it cannot be an input side fault but more from after the pre-amp stage.
This happens with either a guitar or nothing plugged into it.
I have inspected the main board and found nothing un-toward. I checked the caps with an ESR meter and everything was in spec.
The amp was bought in 2008 and is on the original tubes... but that being said, it has not been used very much at all in that time. (I happen to dislike this amp - but cannot sell it or use it in this state!
 ).  Can this be a sign of dying tubes?  I have heard they can make all manner of strange noises when on the way out.
 ).  Can this be a sign of dying tubes?  I have heard they can make all manner of strange noises when on the way out.I recorded a video and uploaded it to Youtube so you can hear exactly what it does.
The first video clip - The amp is turned on with no input and approximately 35 seconds later the "blaring" noise happens (You can see the camera flinch as I nearly destroyed my pants
 )The second clip - I am playing through the amp and the same thing happens. After the noise the amp functions perfectly afterwards.
The third clip - The amp was turned off and the Noise happened, almost like the caps bleeding off... very strange?
So thats the issue. Have you ever heard of anything like this?
As I say I am not a huge fan of this amp, but cannot get shot of it or even use it in this state.
I would try and replace the tubes if that will cure it but I dont want to throw money at something I kinda hate.
 Thanks in advance guys.
Regards,
Stevo
