Bypassing Tone Stack AB763 DR
thisismyname
Post by thisismyname »
I'm thinking of experimenting with no tone stack on the normal channel "wired as a lead channel) of my Deluxe clone so I can get more gain . Instead, I want to use an EQ pedal.
Unless I'm overlooking something, I think I can just go from the plate of the first gain stage directly to the volume pot.
However, I know I'll need a coupling cap. Any suggested values for this circuit?
Roe
Re: Bypassing Tone Stack AB763 DR
Post by Roe »
thisismyname wrote: Fri Mar 12, 2021 7:07 pm I'm thinking of experimenting with no tone stack on the normal channel "wired as a lead channel) of my Deluxe clone so I can get more gain . Instead, I want to use an EQ pedal.
Try a 2n cap to a1m pot
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
Colossal
Post by Colossal »
Before you go to great lengths, you might consider putting a SPST switch in between the tone stack and ground for your boost. Also, do a search for the Raw Control mod. This is basically a 250k bypassable pot between the tone stack and ground which allows the user to dial in the desired amount of "rawness" or lift from ground. As for a coupling cap, 0.022uF would be fine to keep the low end in check.
