Getting a smoother OD
ijedouglas
Re: Getting a smoother OD
Post by ijedouglas »
If you are happy with your cleans, I would give it time to break in and then re-evaluate your OD.
What are your plate voltages?
If it is still too harsh I would concentrate on components around V2 as well as the OD trimmer.
I would also recommend changing one thing at a time and re-evaluating whether you are closer or further from your goal.
Things to try:
- 68K 1 watt Piher Carbon Film grid stopper on V2a (you can find these on ebay)
- Carbon film 180K on V2b
Ian
andyhardy
Post by andyhardy »
Was just looking at your snubbers on V2
They look like they are wired between pins 2 and 3 and
pins 6 and 7
should be 1 and 3
6 and 8
philbard
Post by philbard »
Here is a voltage chart. First time for this, hopefully its accurate
Phil
Charlie Wilson
Post by Charlie Wilson »
The Dales on the grids would not be my first choice and the metal films on the LNFB either.
CW
philbard
Post by philbard »
Here is the voltage chart as a jpg...
Phil
philbard
Post by philbard »
Charlie Wilson wrote: Thu Dec 24, 2020 11:28 pm The Dales on the grids would not be my first choice and the metal films on the LNFB either.
CW
Heard that from Ian as well, I'll look into replacing. Suggestion for brand and sources?
Phil
hywelg
Post by hywelg »
Seriously, wait until its burnt in. And it takes a while unless you have a load box and can let it run continuously. I built my Ceriatone OTS way back in 2008, burn in wasn't really recognised back then and I modded mine to add a stepped hi-cut to the OD circuit. After about a year or so of very intermittent gigging the cut stays on zero or first notch only. I've never got around to removing it. It could easily be an on-off-on toggle sw.
philbard
Post by philbard »
andyhardy wrote: Thu Dec 24, 2020 10:29 pm Was just looking at your snubbers on V2
pins 6 and 7
should be 1 and 3
6 and 8
Just checked, they are 1-3 and 6-8. Probably hard to tell from the first gut shot.
Phil
Charlie Wilson
philbard wrote: Thu Dec 24, 2020 11:31 pm
CW
Bought a pair of sneakers and they were a little tight, guy at the store said don't worry they'll break in. Ended up with torn seams in the shoes and shin splits. Sorry I had to be a wise guy. :D Sure let it break in if you want. Can't hurt. At least not as much as those shoes did. You've got Xicon 1w carbon films everywhere else, so maybe try those on the grids. For 10meg on your LNFB buy these https://www.ebay.com/itm/10-meg-1-4-wat ... 2749.l2649. Tony turned me on to them and they are the only ones I have liked so far in that spot. I bought a few more before I posted this. :D
CW
philbard
Post by philbard »
Charlie Wilson wrote: Thu Dec 24, 2020 11:50 pm
CW
CW
Thanks Charlie, ordered the 10 megs already and will look for the Xicon's.
Phil
Charlie Wilson
The Xicons are pretty easy to source. Mouser, Antique Electronics, etc. Don't get 1/2 watt, they don't sound that good. Get 1w. Also, lead dress. Cut that zip tie around your OT leads and get your OD cathode and plate wire away from the secondarys. Dumble likes to run the two cathode wires right next to each other. Sorry, one more thing. Get a 110k and 120k carbon film for your PI plates. My bad, just noticed the tied wires are your loop wires not OT. :oops:
CW
philbard
Post by philbard »
Charlie Wilson wrote: Fri Dec 25, 2020 12:10 am The Xicons are pretty easy to source. Mouser, Antique Electronics, etc. Don't get 1/2 watt, they don't sound that good. Get 1w. Also, lead dress. Cut that zip tie around your OT leads and get your OD cathode and plate wire away from the secondarys. Dumble likes to run the two cathode wires right next to each other. Sorry, one more thing. Get a 110k and 120k carbon film for your PI plates. My bad, just noticed the tied wires are your loop wires not OT. :oops:
CW
Thanks for the ordering info, done.
Yeah, threw me off for a moment there on the ties. No worries...
Phil
Charlie Wilson
I'll throw you off a little more. :D In the photo you have a mini zip tie on your OT leads and one on your PI input(loop) leads. You may want to get the loops wires away from your OD wires after all. There is a good amount of signal going through those and it could, maybe, dirty up the OD a bit. Study the picture I took of #94. It is a good example of how Dumble typically did his lead dress.
CW
Mr. dB
Post by Mr. dB »
martin manning wrote: Thu Dec 24, 2020 4:51 pm
philbard wrote: Thu Dec 24, 2020 2:10 pmNo way for me to know how big a role the OT plays in my build since this is my first. If I wanted to swap do you know which model Heyboer I would need?
The standard ODS OT is Fender Twin Reverb/Showman, so you want the equivalent to that. The Heyboer site directs retail customers to buy from Mojo, whose Twin Reverb part number is 775. No one here has heard your amp yet, so we don't know how smooth it is or isn't ;^)
This is a 50W, so the Bassman transformer would be the usual choice, no?
Mr. dB wrote: Fri Dec 25, 2020 4:03 amThis is a 50W, so the Bassman transformer would be the usual choice, no?
Indeed you are correct... Blackface Bassman, Mojo 774.
