Hi guys,
having a lot of amps standing around and taking my place to live, I would like to build a stompbox preamp with two 12AX7.
There's an available voltage pump kit that supplies a maximum of 15mA @ 220V DC out of 4 VA @ 12V DC input.
I don't expect this preamp to be a close reproduction of the Dumble sound but would 220V get me in the ballpark?
Thanks a lot!
						Sufficient B+ for Dumble kind of preamp?
- pompeiisneaks
- Site Admin
Re: Sufficient B+ for Dumble kind of preamp?
I found this looking through the #124 section: https://ampgarage.com/forum/viewtopic.php?f=5&t=5719
V1: 190VDC, V2: 200VDC/210VDC
Then another note later:
So yes, that voltage 'should' put you in the ballpark, but you'll need to play with the a dropper resistor before the V2 tube and then another for V1...
But...
That's definitely only one component in the variable list...
									Which if I do the math means;B+ is 440VDC on the 6L6 plates, which seems low. The remaining plate voltages are: V1A and V1B approximately 190VDC each; V2A and V2B 10 volts higher; on the order of 280VDC for the non-feedback side of the phase inverter plate, and about 10 volts higher for the feedback side.
22) Were any voltages measured when the amp was examined?
Yes, as follows:
V1 190v
V2 200v
6L6 Plates 440v
PI plates 280v and 290v
But...
Yes, preamp tube plate voltages are 190-200V, but that means the supply voltage would have to be about 300V at 5mA to replicate the ODS operating points.pompeiisneaks wrote: ↑Thu Nov 19, 2020 6:56 pmWhich if I do the math means;
- pompeiisneaks
- Site Admin
Ahh you're right, I didn't think of that exactly, so that's direclty ON the pin...martin manning wrote: ↑Thu Nov 19, 2020 7:09 pmYes, preamp tube plate voltages are 190-200V, but that means the supply voltage would have to be about 300V at 5mA to replicate the ODS operating points.pompeiisneaks wrote: ↑Thu Nov 19, 2020 6:56 pmWhich if I do the math means;
So yeah, that definitely won't work unless you use a FWB Rectifier, which should make the output voltage be over 300V? (FWB is 1.4x the output AC whereas FW is .9) that would work I think?
The OP is wanting to use a SMPS of some kind to get the HT from a 12VDC input. Looks like the one he is considering tops out at 220V.
						- pompeiisneaks
- Site Admin
I'll hush and stop derailing with my misunderstandings then.
Right, the PSU delivers a maximum of 220V - is it worth trying?
That's the voltage pump I would use:
https://tube-town.net/info/datenblaette ... t_v1_6.pdf
