I am an unapologetic fan of Carr Amps. Steve Carr makes a mighty fine combo.
I was researching the Slant 6V--a 40 W quad-6V6, 2-channel amp with reverb. The amp runs the 6V6 tubes in pairs--one pair with adjustable-fixed bias and the other pair with cathode bias. You can select between the pairs for the preferred bias type/sound in separate half-power modes. Or when running in full power mode, each pair uses its own bias circuit simultaneously.
Does anyone know of a clear schematic file for this amp? I found a pencil-drawn low-res version somewhere here that is very difficult to read.
Are there any other amps that share this design?
Simultaneous Fixed and Cathode Bias power tubes
Just plug it in, man.
Re: Simultaneous Fixed and Cathode Bias power tubes
It comes from Mesa's Simulclass, where one pair was running cathode biased (in triode, in that case), while the other pair(s) in pentode fixed bias.
You can use that schematic as a starting point.
The Mesa schematic is a start, yes but his amp in question keeps all 4 tubes in Pentode mode.
Many of the CBS era Fender silverface high power amps used a underlying cathode biased output stage besides the normal fixed bias.
These amps don't have the ultimate punch of the fully fixed bias amps, but to me they have a very usable sweetness to them !
Here's the schematic I found online:
