HELP Identifying Input Jack & Speaker Out..
zozoe
Post by zozoe »
Hi all & hope all are well~ Kindly look at this project I picked up, and the seller knew absolutely nothing about it,, He thought those 2 wires, circled on lower right, were the speaker connections, one wire going to the jack, & the other one going to a ground post on the chassis... Is what I reasonably assumed to be the input (1/4"), indeed the speaker out? And that other oddball jack, (which will be changed to a 1/4"), has that black lead going to the Volume control, & the green wire is going some pin on the 5879 tube, & the 2 upper lugs are tied together....So, is that jack really the amp's input, & if so, which lead is hot? I'm forever learning, & just trying to figure this one out 🤔~
Thanks all~
Re: HELP Identifying Input Jack & Speaker Out..
Post by Stevem »
The output transformer is on the bottom side of the amp and the secondary side of it that feeds the speakers is on the right side of it next to the fuse holder.
We need a better picture of that side of the chassis to figure things out.
zozoe
Post by zozoe »
Thanks guys,,, Hopefully, these shots may help solve the mystery,,, That's a 3 conductor 1/4" input/out, with that Green wire going nowhere, & the black going the far left tone lug, which is tied to the middle lug,,,, the Brown wire goes to a post that shares a connection that comes off the 6SL7... Then there's that strange(to me) mess on the other end...
zozoe
Post by zozoe »
STEVEM,,, anything for me?
Thnx
zozoe
Still Seeking HELP Identifying Input Jack & Speaker Out..
Post by zozoe »
Hi all,, I think I've got it, but i need it from the experts,,, you folks. Please read the short thread above to see what's going on.
Many thanks~
Kenny
mhuss
Post by mhuss »
I suspect green is hot and black is common on the input.
The 1/4" is the output. Looks like the 300R resistor is just using the jack as a ground connection?
zozoe
Post by zozoe »
Thanks, MHUSS, I thought so....
Kenny
