Hi all, & hope all's well.. Here's a pic of the back panel of my Bell & Howell 12643, aka model 138, & the associated schematic (in 2 parts), & not wanting to remove that jack, can anywhere help me make heads or tails of it?
Many thanks in advance for any assistance.
Kenny
Help With Cinch? Speaker Jack on Old Amp
- pompeiisneaks
- Site Admin
Re: Help With Cinch? Speaker Jack on Old Amp
It is a 6 pin cable that connects between the amp an a 'speaker case'
Based on the schematic, it looks like a remote switching system for the 'speaker' which likely had it's own amp and power supply. You can ignore the jack and circuit because it's not physically connected to anything internal -- but -- there may be a relay contact somewhere that needs to be bypassed for the preamp to turn on.
Thanks MHUSS, So there is hope for this project w/o the original case w/speaker & tranny?
Again, kindly detail exactly what I need to do in order to get this into a stand alone amp,, then i can pass it off to my tech to do said work.
Thanks all & be well~~
Hi again,,,I have a tech, a rather experienced old chap who has been able to circumvent any amp issues I bring him, but I just wanted to get a better understanding of what I'm bringing him, and so I can add any appropriate jacks on my own. Yes, he's an amp guy, but not a musician, as much as I'm not a tech, & the more info I have about what I'm dropping off, the better I can present it. From the git-go, assuming there is an electronic fix to this not having the original speaker/cabinet, would it be appropriate for me to 'prep' this amp w/a 1/4" speaker out, in anticipation?
Thanks so much!!
Kenny
Thanks so much!!
Kenny
thetragichero
is the output transformer in this chassis or elsewhere?
i prefer to rip out everything that's not being used as it can make it less confusing
yes i would imagine having a 1/4"jack so that you can plug it into a speaker cabinet would be rather beneficial
Well, here's the bottom side of the power tranny, & I'm not quite sure what that thing below it is, but there's wires going in & out, & it's fastened down pretty well?
Yes, in a previous B&H refurb, much of the guts related to the projector was removed, but some still remain.
Thnx
Thnx
thetragichero
most/all of that stuff should be removed. gut the thing and build a guitar amp in there. i find it exponentially easier to start with a bare chassis and only put things needed than trying to repurpose stuff that might be extraneous anyway
