I wanted to know if there is a way to increase the wet mix on the Reverb. I upgraded the reverb pan and that helped but even with the Reverb mix all the way up it still isn't as wet as I'd like it to be.
With just a ratty little 12AX7 section, Boogie reverb circuits can't drive much nearly as much power into the tank as Fender reverbs that use a parallel pair of 12AT7.
I'd look at trying a JJ ECC823 to push more signal into the tank (and linking out the R58); then you've got more chance of getting a decent signal out of it
May benefit from tweaking the bias for the ECC82 drive section.
12dw7 is so great for single tube reverb (generally using organ salvaged tanks with higher input impedances so i have yet to use a transformer-driven reverb)
PRR wrote:
Plotting loadlines is only for the truly desperate, or terminally bored.
Stevem wrote: ↑Mon Aug 31, 2020 10:52 am
Increase C29 to 22 to 25 uf.
Do you mean to 22 or 25uf?
pdf64 wrote: ↑Mon Aug 31, 2020 3:16 pm
