ODS Pedal Parts
donvan
ODS Pedal Parts
Post by donvan »
Time to build a pedal for my 183 circuit. I'm using this panel mount 5 pin DIN on the amp: mouser 161-0005-E
Can anyone tell me a part number for the male jack that goes with this? While we're at it, what cable, footswitch box, and LEDs do you like for your pedal?
Thanks so much!
Re: ODS Pedal Parts
A standard midi cable will work with that jack, I believe. For the box, many people have adapted the Marshall footswitch boxes sold by AES. I added a DIN jack to mine so the cable can be detached.
donvan
Re: ODS Pedal Parts
Post by donvan »
martin manning wrote: Fri Apr 17, 2020 4:53 pm A standard midi cable will work with that jack.
I just tried a midi cable and it doesn't fit.
Thanks for the tip on the Marshall pedal.
Re: ODS Pedal Parts
Hmm, that's odd. 5-pin DIN with all 5 in 180 degrees is standard. Is that what your jack looks like?
norburybrook
Re: ODS Pedal Parts
Post by norburybrook »
that mouser part is a 5 pin 180 deg socket. As Martin said a midi cable should fit.
is your socket 180deg?
I use hammond FX pedal enclosures for my foot switches, LED's? use whatever you fancy, be aware that the super bright ones can bee seen from space!!!!!
I use start quad cable for my footswitches. it has 4 conductors and a shield, so perfect for the 5 pin DIN
M
donvan
Re: ODS Pedal Parts
Post by donvan »
I was wrong. The cable I tried had only 4 pins. It looked like a midi cable but was not. Just tried a real midi cable and it worked. Thanks for the tip!
rootz
Re: ODS Pedal Parts
Post by rootz »
My last build uses a 1950a box (small!) as a foot switch. PAB and OD can be linked with a switch, so PAB can be automatically switched on when OD is engaged. I think this can be done with a standard MIDI cable setup like Dumble uses. I use a standard stereo jack for switching though (relay and led series like Two Rock does instead of parallel like Dumble). Works just as good, just need to use a relay that draws less than 20mA, otherwise the LEDs will burn.
donvan
Re: ODS Pedal Parts
Post by donvan »
Thanks rootz!
donvan
Re: ODS Pedal Parts
Post by donvan »
The pedal turned out great using a Hammond box and midi cable but with a little drama along the way. Apparently the midi spec only uses 3 of the 5 pins. I had two ancient midi cables. One cable did not connect the unused pins. The other cable had the unused pins wired to ground! This was harder to track down then it should have been. Anyway, the lesson here is: Make sure you buy a midi cable with all pins connected correctly.
Re: ODS Pedal Parts
Sorry, could have warned you about that!
norburybrook
Re: ODS Pedal Parts
donvan wrote: Tue Apr 28, 2020 8:37 pm The pedal turned out great using a Hammond box and midi cable but with a little drama along the way. Apparently the midi spec only uses 3 of the 5 pins. I had two ancient midi cables. One cable did not connect the unused pins. The other cable had the unused pins wired to ground! This was harder to track down then it should have been. Anyway, the lesson here is: Make sure you buy a midi cable with all pins connected correctly.
you've missed out on the deep joy of soldering a midi cable........ my favourite .....NOT..... :)
M
donvan
Re: ODS Pedal Parts
Post by donvan »
norburybrook wrote: Wed Apr 29, 2020 9:13 am you've missed out on the deep joy of soldering a midi cable........ my favourite .....NOT..... :)
M
As bad as that sounds it would have been better than rabbit hole I went down chasing this somewhat simple problem.
Aurora
Re: ODS Pedal Parts
Post by Aurora »
I'm looking for a sloped blank box that could house 4-5 switches.... without buying a original Fender or Marshal pedal....
Any tips??
donvan
Re: ODS Pedal Parts
Post by donvan »
Aurora wrote: Wed Apr 29, 2020 7:57 pm I'm looking for a sloped blank box that could house 4-5 switches.... without buying a original Fender or Marshal pedal....
Any tips??
Check out Hammond boxes at Mouser. Here's one I found with a quick search. It's pricey but there are many.
https://www.mouser.com/ProductDetail/Ha ... npDzVp4%3D
Aurora
Re: ODS Pedal Parts
Post by Aurora »
Thanks for reply.... I know of those, but aren't they rather flimsy for a pedal? Anyone really used those for pedals?
