Isolation transformer hum
Koolaide
Post by Koolaide »
Well I completed the enclosure and wiring for the IT. It is a wooden enclosure primaries attached direct to power cord (with wire nuts)and secondary's attached directly to a standard 110v outlet. The outlet is mounted to 2 metal L brackets bolted to wood base. No grounding. I connected to variac today and as I turn up the voltage hum is there and increases. Note the variac is grounded. Shop has florescents overhead. I did not notice this hum when I tested the IT - plugged into variac with wires and jumpers and connected to meter with jumpers?????
Should I be concerned?
Koolaide
Re: Isolation transformer hum
Post by Koolaide »
Just to clarify above post the output voltage is about 1.5% of input voltage just as in original test. Test were without load. Hum is not bad but it is there. I suspect all is OK.
Line the enclosure with tin foil. Apply a light layer of ordinary glue. Lay foil on the glue. Rub with a rag. This will shield the IT. Of course, it could easily be something else picking up the florescent light. When I am finished with an amp, I attach foil to cardboard to cover the open side during testing. Then I line the bottom of the cab with foil. It's cheap and it's easy to do.
Are you talking about hum you're hearing from the speaker, or mechanical noise emitted by vibration?
Koolaide
Post by Koolaide »
xtian wrote: Wed Apr 15, 2020 1:42 am Are you talking about hum you're hearing from the speaker, or mechanical noise emitted by vibration?
No speaker connected. Great question!
I would assume or mechanical noise emitted by vibration. It does change slightly when I touch the transformer, Seems to lessen. I turned off the lights, and the hum (if you will) is still there. Again it is slight, but clearly audible. Should I be concerned?
Thanks for the input Aaron.
Maybe your wooden enclosure is amplifying the normal hum coming from the transformer?
Koolaide
Post by Koolaide »
You could be right Martin. Think I'll pull the enclosure off and see. The transformer is mounted to a wooden base and the enclosure fits over the top.
Koolaide
Post by Koolaide »
pulled enclosure, it helped slightly. But still there. Shield with a metal plate no change. The question remains.... to be continued. I'll work on it some more tomorrow.
All transformers vibrate mechanically, some worse than others. Sometimes you can mitigate by applying more torque to the fasteners.
Koolaide
Post by Koolaide »
I tightened the laminations (very little)- decided this is normal transformer noise. Thanks all for the input.
Now on to installing a digital meter on my variac. The saga continues.
didit
Post by didit »
One can strip away mounting and bells, and pot the core in a can. Most effective hum reduction though adds costs and makes any repairing an ugly mess.
Best .. Ian
Koolaide
Post by Koolaide »
Thanks Ian,
I considered potting it, but as you note it could get messy. As for end bells, there aren't any.
On a side note, I finished the Variac mod, and an on to building an amp cradle. Think I'll finish that later today or tomorrow.
For mechanical vibration, you might try mounting on rubber grommets.
Koolaide
Post by Koolaide »
hadn't thought of that one. Thanks Phil.
Those cone shaped plumbing washers, relatively firm black plastic/rubber, should do nicely if you have nothing else. You can probably get them for $1 at the big box store.
