LND1500 loop issues
				studiodunn
LND1500 loop issues
I have built 2 of these and both have the same issue with not passing a good signal through.
The signal is thin, weak and obviously off from the bypassed signal. There is also signal bleeding through when it’s bypassed
The return takes a signal fine, but the send side has issues. The input has 310v and all my components have been double checked against a few schematics.
This is the schematic I built from and I’m not seeing anything drastically different from other versions of this loop I’ve seen.
What am I missing here?
Re: LND1500 loop issues
Looks like the send stage has a LOT of feedback, and it drives the loop from the drain, where most send buffers are source followers.
Where did that come from? Are you sure it is correct?
				frankdrebin
Schematic is the metro amp zero loss,and it works as intended.
If it doesn't work it's either a faulty MOSFET,wrong component or bad execution.
				pdf64
It’s worth confirming that the 10 ohm resistor on the send is wired as a 0V lift, rather than a load
How about taking a voltage survey, and adding the readings to the schematic?
The ‘bleed through on bypass’ issue description seems kinda cryptic, really needs a heap more detail adding.
On the face of it, it may support the ‘bad execution’ hypothesis.
How has the bypassing been achieved, perhaps a pic of the wiring might help debug the circuit, or rather the installation of it.
It's a very neat design, using so few components in the send stage, but achieving all that's needed. I noticed that the gate of the first stage hasn't got any protection diodes, I think the feedback might help keep the gate well within spec, but could that be a problem. I doubt that it would be. Just a thought.
				studiodunn
Some pics and voltages. I’m not sure what’s happening at R1-100k but I’m guessing the issue lies there.
[attachment=1]46C36FC0-E667-46E1-8D55-AE580CB6B056.jpeg[/attachment]
No voltages visible?studiodunn wrote: ↑Tue Mar 10, 2020 4:33 pm Some pics and voltages. I’m not sure what’s happening at R1-100k but I’m guessing the issue lies there...
The circuit is in very close proximity to other circuits, specifically the 2 tube sockets underneath; maybe there's some unintended coupling going on, have you scoped for oscillation etc, have you checked to see if the board works if it's elsewhere, ie away from that place in the chassis?
That schematic cam be quite improved imho.
I would use a voltage divider at the input of the schematic, then use a stronger mosfet for it (IRF820?) with more current flowing through it but less feedback, then add feedback on the return stage.
				studiodunn
pdf64 wrote: ↑Tue Mar 10, 2020 6:28 pmNo voltages visible?studiodunn wrote: ↑Tue Mar 10, 2020 4:33 pm Some pics and voltages. I’m not sure what’s happening at R1-100k but I’m guessing the issue lies there...
Sorry, they are up now.
And yes, I moved the board and got the same results.
Why I'm going from 330v to 1.41v after the 100k resistor will surely shed some light on the problem.
I have bulit 3 Metro loops and everyone went in and worked without issue. I'm not saying I couldn't or didn't make a mistake, but for both loops to do the same thing( and not in the same build) has me confused.frankdrebin wrote: ↑Tue Mar 10, 2020 12:05 pm Schematic is the metro amp zero loss,and it works as intended.
I also replaced the MOSFETs in the loop shown to eliminate that being the culprit....no change.
I think voltages on the driver stage should be something like this:
				studiodunn
I wish they weremartin manning wrote: ↑Tue Mar 10, 2020 11:27 pm I think voltages on the driver stage should be something like this:
Those green mylar polyester caps, I've only ever seen them rated at 100v.
Q1 is hard on, RDSon looks to be about right, so what are the driving voltages. What amp is it, and where is the loop being inserted.
                                            2 others liked this
...suggesting that C2 is leaking DC.
				studiodunn
330v off the B+ in a Wizard Mtl 100w build. The Loop is fed directly from the Tone stack, out to the PI
				Ten Over
                                            2 others liked this
The Q1 LND150 is functioning properly for a bias of +0.64V.  The question is why there is 1.3V on the Gate creating that +0.64V bias.  I agree with martin about C2 being a prime suspect and I would lift C2 and then measure the voltages.
The expected bias of -0.6V from the diode on the Source of Q1 would cause an idle current of 0.5mA according to the LND150 literature. This would give you a Drain voltage of 280V if the supply voltage remained at 330V, but it probably won't. As it sits, Q1 is taking down 3.3mA and Q2 is taking down around 0.8mA causing a 45V drop across what looks like an 11K dropping resistor (R8). If Q1 starts running at the expected 0.5mA, the drop across R8 will only be 14V and the Q1 Drain voltage could be 311V.
