bassman 6g6b ohm question
jamme61
Post by jamme61 »
my bassman head is 4 ohms, I only have 8 ohm cabinets - can I add a 8 ohm dummy load to the external speaker jack- with the 8 ohm cabinet connected and get a 4 ohm load to the amp?
Re: bassman 6g6b ohm question
You need an 8-ohm load in parallel with the speaker, so yes. And you'll get about half the power out.
jamme61
Post by jamme61 »
thanks- would this be better for my amp then running the mismatched impedance? (4ohm amp into 8 ohm cabinet) thanks for the help
Many people will say miss-matching by a factor of two is ok, but I wouldn't do it.
pompeiisneaks
Site Admin
Post by pompeiisneaks »
From hughes and kettner, I've read this and it seems to fit with my general understanding as well:
http://blog.hughes-and-kettner.com/ohm- ... impedance/
jamme61
Post by jamme61 »
thanks for the info - i'll try a dummy 8 ohm load in parallel with the speaker cab tomorrow and see how it sounds. I've used my bassman head for years with the mismatch but never felt comfortable about it.
Roe
Post by Roe »
A 16 ohms parallel load is plenty good. merely running a 8 ohm load into the 4 ohms secondary, by contrast, may stress the screens (depending on voltages, tubes etcs) and will reduce the power by ca 30% and you will loose some bandwidth.
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
jamme61
Post by jamme61 »
so 16 ohm with my 8 ohm cab gives me 5.3 ohms- right? which means less volume and detail loss- yes? better for my amps output transformer?
I tried the 8 ohm load and noticed less volume and less high end. the output transformer stayed cool to the touch but the load I made ( 8 ohm 100 watt Xicon resistor) got up to 175 degrees after about an hour of use. thanks again for the help
should I use something like this instead? - https://www.mouser.com/ProductDetail/AR ... eqMtbnA%3D
