Love to hear your thoughts and what youve all found with your ears too.
It's worth noting that, to my knowledge, this is a hypothesis, rather than proven theory; and it might seem to goes against the importance some folks place on the particular cap type used for the instrument's tone control (where applicable), ie where the signal Vac is at/near its lowest?
With or without the dc blocking cap / polarising voltage, the Vac feeding the tone stack caps is surely barely affected?
Well, that capacitors are more prone to divert from specs when close to their limits, is not hypothesis. I also remember some tests done by caps producers, not dowsers.
It's something I've never tried myself directly, so I cannot comment, but alot of people hear differencies here also. This doesn't mean that there are no differences on the opposite conditions.
Usually caps are between 100 n and 1uF, so their effect is not so big even at lowest guitar frequencies (19k4 on the former, 1k94 on the latter). If that is the case, why not just a 2k2 up to 22k resistor in series instead?
I've experimented with 1uf caps before the tone caps and could hear no difference. I have pretty sensitive ears. Some brands like diesel use a .22uf in the same spot, again, I just don't hear it.
Not sure you understood my point. Not claiming that cap type is inaudible in a tone circuit, I'd argue the exact opposite. Only that blocking dc before the tone caps with a cap large enough to pass all present audio frequencies is, in my experimentation, inaudible vs. not doing that, all other things held constant.roberto wrote: ↑Wed Apr 08, 2020 7:48 am Hi Ray,
I think that the debate "I hear it" vs "I don't hear it and my last hearing test shows flat from 20 Hz to 20 kHz" without any other comment is quite old and it is proven that brings nowere.
Oh well, to be fair it usually brings granitic minds to create walls and start flaming. It is not my case and I'm sure it is not yours.
Caps have usually huge tolerance compared to resistors, so even swapping two caps of the same brand can give a difference. This is well known.
Then there are circuits where it can be heard more, and some less. There are points of the circuit where it can be heard more and some less.
I noticed the difference when in extreme high gain (not my bread), way less in normal clean.
That said, I don't use the Engl/DieZel preEQ-cap in my amps.
When a dc blocking cap is inserted between the tube and tonestack, the source impedance feeding the tone stack will now have a frequency dependent element. Agree that there may not be much of an effect if it's 1uF, but moreso with lower values.
