Low Bias Current - Carvin X Series III 60W
BungleSim
Post by BungleSim »
I'm repairing a Carvin X Series III 60W amp, which I guess is supposed to be a Mesa Mark III copy. I'm using the OT shunt method to bias the tubes and I'm reading a bias current range of about 18-30mA when I turn the bias pot, so I'm not hitting the expected current of around 44mA to reach 70% plate dissipation. With the bias pot in the middle I'm reading about 21mA so something seems off.
The pot is good and I'm seeing around -52V out of it. Schematic is attached, though it shows four 6L6's in the power amp but this amp only has two 6L6's. Any ideas on what I should troubleshoot would be greatly appreciated. Thanks!
Carvin X-Amp Series III.pdf
sluckey
Re: Low Bias Current - Carvin X Series III 60W
Post by sluckey »
With standby switch open monitor the voltage on pin 5 of a 6L6. What voltage do you read with the bias pot turned to one extreme? What voltage do you read with the bias pot turned to the other extreme?
Also, 70% target is largely "old wisdom" and we (I) more sanely bias in the 50-60% range. Sounds good, tubes last longer, less prone to burning things.
JD0x0
Post by JD0x0 »
70% is MAX dissipation in class A/B fixed bias. It is not the general recommendation. Some people, may find in some circuits it sounds best there, but I find that rarely to be the case. Many channel switching amps are Biased under 60% dissipation. Blackface Fender spec was around 50-60% dissipation. Many 'High Gain' channel switchers run even cooler than that. It's not uncommon to find ~30% dissipation in 'Metal amps' I'd say your 'middle' setting of 31.5% sounds about right. If you want a bit more range, you can adjust values in the bias supply. I suspect the relatively cool setting at max is to prevent dummies from cranking the bias up to max and over dissipating the power tubes. I suspect, much like 5150's and other similar high gain amps, they biased these cool on purpose, and essentially are only set hot enough to avoid noticeable crossover distortion.
BungleSim
Post by BungleSim »
sluckey wrote: Wed Feb 05, 2020 4:48 pm With standby switch open monitor the voltage on pin 5 of a 6L6. What voltage do you read with the bias pot turned to one extreme? What voltage do you read with the bias pot turned to the other extreme?
Pin 5 voltage measurement ranges from -54.3V to -46.8V at the bias pot extremes.
JD0x0 wrote: Wed Feb 05, 2020 5:59 pm 70% is MAX dissipation in class A/B fixed bias. It is not the general recommendation. Some people, may find in some circuits it sounds best there, but I find that rarely to be the case. Many channel switching amps are Biased under 60% dissipation. Blackface Fender spec was around 50-60% dissipation. Many 'High Gain' channel switchers run even cooler than that. It's not uncommon to find ~30% dissipation in 'Metal amps' I'd say your 'middle' setting of 31.5% sounds about right. If you want a bit more range, you can adjust values in the bias supply. I suspect the relatively cool setting at max is to prevent dummies from cranking the bias up to max and over dissipating the power tubes. I suspect, much like 5150's and other similar high gain amps, they biased these cool on purpose, and essentially are only set hot enough to avoid noticeable crossover distortion.
xtian wrote: Wed Feb 05, 2020 4:58 pm Also, 70% target is largely "old wisdom" and we (I) more sanely bias in the 50-60% range. Sounds good, tubes last longer, less prone to burning things.
All of this is great information. Thanks a lot, guys! So if I throw out the general recommendations and tables that I've been using according to sites like this, how do I go about reliably setting the bias on this amp? Guess and check?
Keep using the tables! The current calculations are correct, it's just that you don't want to set to 70% by default.
wpaulvogel
Post by wpaulvogel »
Use your ear and because it’s never going to bias into dangerous dissipation levels turn it and play. Find the sweet spot.
BungleSim
Post by BungleSim »
OK, cool. Thanks, guys! :D
