help me make a mid control
thetragichero
Post by thetragichero »
okay so instead of your standard tmb stack I'd like to throw a more effective mid control along with maybe a James (love me some James tone stack!). i was thinking of something low Q, couple of octaves centered around 600hz or so. I've got a number of inductors around, so i searched for a calculator for a simple lcr filter and ended up with this:
I've got at least two triodes available (half a 12ax7 and half a 12au7), but coming to difficulties on designing for tubes (pretty sure i could make a mid boost/cut with a single op amp)
i have looked at a number of schematics, most helpful were ampeg (most of them use four triodes, one version of the v4 uses three. all seem to use more switching and options than I'd like)
I'm open to suggestions!
Re: help me make a mid control
Post by Stevem »
Is this for guitar or bass?
600 HZ even for guitar is getting pretty high up out of the mid range , as a high D on the E string is less then 1200 HZ if I recall right
thetragichero
guitar. i might play with frequency, that was just the first number that popped into my mind with values that would work in the real world. to me the exact frequency is like the seasoning added to make it tasty. I'm just looking for the recipe to experiment with. i suppose i could investigate "tube differential amplifier" (just thought of it now)
I'm a pretty good googler so part of the reason for the thread is so that the next hack like me who's looking to do this will have an easier time. wu's for the kids, as the man said
thetragichero
I'm thinking if i run a phase splitter (concertina would be great), inverting out to one of the outer lugs of our mid pot (what value do ya think?), non-inverting out to the other outer lug. center lug to our lcr filter
all of that in parallel to our regular tone control, combined at a cathode follower?
wpaulvogel
Post by wpaulvogel »
A bridged T makes a wonderful midrange control. Drive it with a cathode follower for a flat response at full cw setting. Makes a great mid scoop, easy. 2 caps, a resistor and a pot. 600 hz is probably perfect for guitar because every string is producing strong harmonics. Low E 81hz is mixed with 162 & more.
Kagliostro
Post by Kagliostro »
Someting to be tried
K
roberto
Post by roberto »
I posted a very simple and effective solution here, more than 10 years ago:
https://ampgarage.com/forum/viewtopic.p ... ids#p97649
Kagliostro
Ciao Robi :D
K
Colossal
Post by Colossal »
roberto wrote: Sun Jan 05, 2020 11:10 am I posted a very simple and effective solution here, more than 10 years ago:
Thanks Roberto, that is helpful. I'm going to implement Bob I's Baxandall in my friend's bass amp.
roberto
Post by roberto »
OT
Ciao Franco!
So we "meet" on "foreign" sites where ideas stream faster.
I hope to see you more often!
/OT
roberto
Post by roberto »
Colossal wrote: Sun Jan 05, 2020 12:36 pm Thanks Roberto, that is helpful. I'm going to implement Bob I's Baxandall in my friend's bass amp.
Glad you find it helpful.
It's something that is often needed in Baxandall-like eqs, but very rarely implemented.
thetragichero
i have to plug everything into tsc myself but this looks to be the ticket! i prefer bax for treble and bass anyway so this is simple, elegant, and doesn't require extra tubes
thank you thank you!
Kagliostro
Excuse me, just a moment for a short OT
and fortunately :mrgreen: , in our area things are now extremely slow
I too
Thanks, OT closed
Just put a 1MA pot instead of the switch: you'll have a midboost by pot.
connected as rheostat I suppose
Franco
roberto
Post by roberto »
Yes Franco, correct.
Kagliostro
OK
Franco
